Diswoe Switch-01 Won't Connect to Device
If your Diswoe Switch-01 controller does not connect to the device when selected or doesn't appear as an available pairable device, follow this troubleshooting guide for possible solutions.
Causes
Your controller may be off. Check to make sure it is on, or try turning it off and on again.
2
Your controller may be too far from the device. Keep them physically close to each other to ensure your controller can be detected. It reports connecting up to 8 meters, but you may want to move closer to the console if you aren't able to connect.
3
Another wireless device with a conflicting signal may interfere with the controller's signal. Try turning off other nearby wireless devices before attempting to connect again.
4
Most devices have a limit to how many wireless devices can be connected at once. Check if there is room for your controller to connect, or disconnect other devices.
5
Your controller may have low power or be completely dead. Be sure to charge your controller before attempting to connect it.
6
If your battery will not charge anymore, it may be time to replace it. Follow this battery replacement guide.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:5
Past 30 Days:43
All Time:724
