Dell Latitude 5430 Camera Not Working
When using applications (like the camera application or video chat applications), does your Dell Latitude 5430 camera either fail to turn on or an error message such as "0xA00F4244" appears? Use this troubleshooting guide to help diagnose why.
Causes
If using an external camera try to unplug and plug back in camera. If using internal camera look to see if slider is covering camera (if one is present on your model).
2
Sometimes a device being behind in updates can cause an issue with the camera so make sure yours is up to date
3
Go into system settings, then go to camera privacy settings and assure camera access is on.
4
Restart your laptop and during the boot up process, press F2 key to enter BIOS. In the BIOS menu, look for the section labeled ******Integrated Devices. Find the option for the camera assure it is enabled then save changes and exit.
5
If none of the above work then physical camera may be damaged.
Describe your problem in your own words
View statistics:
Past 24 Hours:4
Past 7 Days:8
Past 30 Days:36
All Time:181
