Causes
If both charging cable and charging port are operational, you may have a faulty battery.
Over time rechargeable batteries, such as the one used in the Corsair K65 Plus Wireless, lose their total charge capacity and can run into functional issues. To test the battery plug the keyboard into a charging cord that is known to work and try to turn the keyboard on. If the keyboard works while plugged in but shuts off after disconnecting, then the battery has failed. For repair, refer to the battery replacement guide.
- 30 minutesModerate
If the keyboard does not turn on even while plugged in the PCB may have failed. The major component inside the Corsair K65 is the Printed Circuit Board (PCB). If the previous troubleshooting steps have been completed and the keyboard still does not power on, then the PCB could be faulty. Refer to the printed circuit board replacement guide to repair the keyboard.
Describe your problem in your own words
