CamPark BM20 Buttons Not Responding
If the buttons on your CamPark BM20 baby monitor are not responding to your input, follow this troubleshooting guide for potential solutions.
Causes
Sometimes, buttons on the monitor may become stuck or jammed, causing them to not respond.
Check all buttons on both the baby and parent units to see if any are physically stuck or jammed. Gently press and release each button to ensure they are not obstructed by debris or dust. If a button is jammed, try to clean around it with a soft cloth or cotton swab with Isopropyl alcohol.
2
Ensure both the baby unit and parent unit are fully charged. Plug the units into their chargers and allow them to charge for 2-3 hours. Once fully charged, test the buttons again to see if they respond properly.
3
If the parent unit and baby unit are not properly synced, certain buttons may not function as expected.
Power off both the parent and baby units. Power them back on and follow the syncing procedure outlined in the user manual. Once successfully synced, test the buttons to see if they are now responding correctly.
4
Interference from other wireless devices can cause issues with the functionality of the monitor, including button responses.
Move the baby monitor away from other wireless devices like routers, cordless phones, or other monitors. Ensure that the monitor is not experiencing interference from devices operating on the same frequency. Test the buttons after moving the monitor to a more isolated location to check if the issue persists.
5
If none of the above solutions work, resetting the baby monitor to factory settings may help restore the functionality of the buttons.
Refer to the user manual for instructions on how to reset your BM20 Wireless Baby Monitor. After resetting, set up the monitor again and check if the buttons are now responsive.
6
A malfunctioning button or an internal component may be preventing the button from responding.
Inspect the buttons for any visible signs of damage. Test the button by pressing it repeatedly to check for consistent functionality. If a button remains unresponsive, it may need to be replaced. Follow the button replacement guide to replace the directional or volume buttons.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:3
Past 30 Days:17
All Time:169
