Shop the Holiday Gift Guide
Calypso Washing Machine Error Codes
Last updated on
Before undertaking any of the more time-consuming solutions below, these are a few fundamentals to get you started.
  • Make sure there is power at the wall outlet.
  • Check if a household fuse is blown or if a circuit breaker tripped
  • Check that the washer is properly installed and the water supply is turned on and clear of obstructions.
  • Check all connections before replacing components. Look for broken or loose wires, failed terminals, or wires not pressed into connectors far enough.
  • A potential cause of a control not functioning is corrosion on connections. Observe connections and check for continuity with an ohmmeter.
  • Connectors: Look at the top of the connector. Check for broken or loose wires. Check for wires not pressed into the connector far enough to engage metal barbs.
  • Resistance checks must be made with the washer unplugged or power disconnected.
Safety First! Before you begin, remember that safety is paramount. Always unplug your appliance before attempting any repairs or diagnostics. This precaution is crucial to prevent electric shock or damage to your appliance.
Understanding Your Washer: This guide covers various problems, from water inlet problems to agitation issues or unexpected leaks. We’ve broken down each problem into three key sections:
  1. Problem: Identifies the specific issue you're experiencing.
  2. Why It Happens: Provides a brief explanation of potential causes.
  3. How to Fix: Offers step-by-step solutions to resolve the issue.
Ready to Solve the Issue? With this guide in hand, you're well-equipped to handle washer repairs on your Calypso with ease. Let’s dive in and get your washer running smoothly again!
Causes
Why It Happens?
“PF” flashes if the washer loses power during a running cycle. The washer does not flash “PF” when it is first plugged in.
How to Fix?
  • Press START to continue the cycle from the moment that power was lost, or press STOP/CANCEL to clear the display and completely cancel the cycle.
  • If the above does not work, check the machine controller
2
Why It Happens?
“FL” flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for “FL” to be displayed.
How to Fix?
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
  • Check pump for possible obstructions.
  • Check valve for leaks.
  • STOP/CANCEL to clear the display.
3
Why It Happens?
This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
How to Fix?
  • Press STOP/CANCEL to clear the display.
4
Why It Happens?
If the water fill time exceeds ten(10) minutes, the water valves are turned off, and “LF” is flashed.
How to Fix?
  • Check that the water supply valves are on.
  • Check inlet valve screens.
  • Check water supply pressure.
5
Why It Happens?
If there is any breakdown in communication between the machine controller and the motor controller, “CE” flashes and the unit beeps once.
How to Fix?
  • Make sure the drive motor harness does not have a bad connection.
  • After disconnecting power to the unit, try scraping this coating off the pins.
  • Check for continuity between the serial communication pins P4 to P2 with the connectors in place.
  • Check the quick disconnect at the motor terminal.
  • Check for possible obstruction that may have caused motor to overheat.
  • Check motor controller
6
Why It Happens?
"Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
How to Fix?
  • Check the pump & sump for obstructions & operation.
7
Why It Happens?
"CA" flashes if a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "CI" for instantaneous current limit trip.
How to Fix?
  • This may signify problems with the drive motor, thermal protector, or motor controller.
  • Try washing smaller loads, using the correct amount of HE detergent.
  • Check for objects under the Nutate Plate.
  • Check for proper installation of the recirculation tube.
8
Why It Happens?
"oL" signifies a failure of the relay in the open position. With this failure no power can be supplied to the motor controller.
How to Fix?
  • Check machine control
9
Why It Happens?
"Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
How to Fix?
  • Check pins 1 and 5 of P16 of the machine controller, and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
10
Why It Happens?
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition.
How to Fix?
  • Open the lid or press STOP/CANCEL to clear the display.
  • Check the lid switch if shorted or open.
11
Why It Happens?
If the lid opens while the unit is in running mode, the time remaining will flash in the display.
How to Fix?
  • Close the lid and press START to continue with the cycle.
12
Why It Happens?
"SL" is displayed when the motor controller senses a suds lock condition by analyzing the current draw on the drive motor. If a potential suds lock is detected, the control tries up to 3 times to clean out the unit with a mini-cycle.
How to Fix?
  • See the "Use and Care Guide."
  • Check the pump & sump for obstructions and operation.
  • This may indicate an extra heavy load, excessive detergent & suds, or non-HE detergent use.
13
Why It Happens?
"ob" is displayed when off-balance detection occurs. The motor controller sends a signal to the machine controller that the washer is in an unrecoverable off-balance condition, causing the machine to shut off and display "ob."
How to Fix?
  • The lid must be opened before restarting the cycle.
  • Redistribute the load, close the lid, and press START to continue.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:13
Past 30 Days:72
All Time:648
