Causes
If you are using the laptop on an uneven surface, you may notice that the fan on your laptop is constantly running or is becoming louder, while also overheating.
- Make sure you place the device on a hard, flat surface.
- Check your system settings and switch to a more energy efficient setting.
- Close any programs you are not currently using.
- Use a cooling pad.
- Check to make sure that there is no dust build up on the vents or fan.
- If you notice rattling or grinding sounds, this could indicate that the fan is faulty or damaged. Follow this guide for replacement.
Asus VivoBook S14 Fan and Heat Sink Replacement
- 10 - 15 minutesEasy
If you notice your laptop’s performance is poor, go to your laptop’s setting menu.
- Close background applications you are not using.
- Outdated graphics drivers can cause your laptop to lag, so make sure your laptop graphics drivers are up to date.
- Optimize power settings by switching to a more energy efficient mode.
- Reduce the resolution of your in-game settings to reduce the strain put on your laptop’s processing system.
- Clean the laptop vents and fan of dust using a can of compressed air.
- Delete any files you no longer need to free up storage space.
The screen can become frozen or shutdown due to overheating and / or out of date software.
- Start by ensuring proper ventilation.
- Force a shutdown and restart of the system
- Press and hold the power button until the power indicator turns off.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:13
Past 30 Days:59
All Time:836
