Anker Soundcore Select 3 A3172 Will Not Power On
If your Anker Soundcore Select 3 Bluetooth speaker will not turn on after pressing the power button, this troubleshooting page may help resolve the issue.
Causes
The speaker may not have enough power to turn it on. Therefore, plug the speaker into a power source using a compatible charging cable. Check the charging indicator near the power button. If the light is red, the device is not fully charged. Allow the device to charge until that light turns white, meaning its fully charged. Once fully charged, hold down the power button for 2 seconds to turn the speaker on. If device still does not power on, proceed to the next possible cause.
2
A damaged charging cable can prevent the speaker from charging. Before changing cables, inspect the cable for any noticeable damage. After, try using a different USB-C cable that is known to work with other devices. Plug the cable into a power source and the speaker. If the charging indicator light turns on, that means the device is charging. If the light does not turn on, the cable may not be the cause of the problem. Therefore, proceed to the next possible solution.
3
A software issue may be present that prevents the device from turning on. To reset the device, press and hold down the power button and volume + button simultaneously for 10 seconds. Release the buttons after the time has passed and try to power on the device again. If the device still does not power on, another cause may be present.
4
Debris or damage inside the charging port may be preventing the device from properly charging. Inspect the charging port with a flashlight to see if there is any debris, like dust, in the port. If there is debris, use a cotton swab or compressed air to remove it. Do not insert any metal objects into the port to avoid damaging the port or any internal hardware. After cleaning, plug in the speaker to see if the charging light near the power button turns on. If the light doesn’t come on, the port may be damaged and may require replacement. Anker Soundcore Select 3 A3172 Charging Port Replacement - iFixit Repair Guide
5
If the power button is stuck, the speaker will not turn on. Press the button multiple times to see if one feels a clicking, which indicates the button is not stuck. If button appears stuck, try holding it down for 3-5 seconds to see if the button releases or becomes unstuck.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:5
Past 30 Days:45
All Time:198
