Causes
Power button
- First check if the battery will charge and is fully charged, by looking for indicator lights that light up when plugged in. If the lights show the speaker is charging, but nothing happens when you press power, the button may be broken.
Reset button
- Try a reset by holding down the power button for 10-12 seconds; If that doesn't work out, use a paperclip to press the reset button located near the charging port
For all buttons
- Check for any feedback from the device when you press the button, like a sound queue or voice line that indicates if something happened (or nothing if its not working)
- Check for a physical feeling in the button when pressed, if you feel the button doesn't touch anything on the other side, the inside may have broken and would need disassembly to verify what.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:4
Past 30 Days:23
All Time:423
