Causes
If the buttons on the controller do not respond when pressed, a possible cause may be debris build-up that occurs over time in the void areas of the controller.
- Power off the controller and disconnect it.
- Use compressed air to blow around the edges of the affected button.
- Use a soft brush from the iFixit toolkit to loosen debris.
- If necessary, lightly clean the area with isopropyl alcohol and a cotton swab to remove buildup.
- Allow the controller to fully dry up before powering on.
The controller requires constant updating for optimal performance.
- Connect the controller to a PC using a USB cord.
- Download and launch the application ‘Firmware Updater’.
- Follow the instructions on the screen to install the latest firmware.
- Do not disconnect the controller from the PC during the updating process.
- After updating, restart the controller and test the buttons again.
A loose or damaged internal ribbon cable may prevent button inputs from reaching the main board.
- This requires opening the controller.
- Connect the internal ribbon cable from the button board to the motherboard.
- Follow this guide: Controller Disassembly Guide
Razer Wolverine V3 Pro Battery Replacement
- 30 - 45 minutesModerate
If cleaning and updating the firmware do not resolve the issue, the button mechanism may be worn or damaged. Replacing the button may restore its functionality.
- Follow the replacement guide for instructions on how to remove and install the new component safely.
- Follow this guide: Button Replacement Guide
Razer Wolverine V3 Pro Action Buttons Replacement
- 15 - 30 minutesEasy
Describe your problem in your own words
View statistics:
Past 24 Hours:5
Past 7 Days:26
Past 30 Days:112
All Time:574
