Causes
Check that the USB-C cable is securely connected to the switch and that the power brick is connected to an outlet. If both are securely connected and the controller still does not charge, disconnect the AC adapter from the Switch and the outlet. Let it sit for 30 seconds to reset the connections, then reconnect the AC adapter to the switch and outlet.
If the battery has been charged and it is not holding a charge for long, it may have come to the end of its lifecycle. You will need to replace the lithium-ion battery. Follow this guide to replace the battery of your Diswoe Switch-01 controller.
Diswoe Switch-01 Battery Replacement
- 15 - 30 minutesModerate
Haven't found the solution to your problem?Browse our forum
