Introduction
A couple weeks ago, Apple surprised us with two new iPad announcements. The first iPad on our teardown table only held some Mini changes, so we’re hoping this one has something a little bigger in store. Join us for a teardown as we jump into the Air!
Looking for all the latest teardown updates, big and small? Follow us on Facebook, Instagram, or Twitter for the latest teardown news. For iFixit delivered, check out our newsletter.
Video Overview
Before we pop it open and let all the air out, let's check the official hardware specs:
10.5-inch LED-backlit Retina True Tone display with 2224 × 1668 resolution (264 ppi)
A12 Bionic SoC with embedded M12 motion coprocessor, Neural Engine, and quad-core GPU
8 MP rear camera + 7 MP FaceTime HD camera
802.11a/b/g/n/ac Wi-Fi with dual band (2.4 GHz and 5 GHz) and MIMO support + Bluetooth 5.0
Up to 10 hours battery life
64 or 256 GB of on-board storage
Go ahead and switch to X-ray vision ... oh, you can't? Don't worry—we can't either. Luckily, Creative Electron has our back.
This new Air hails from the Pro line, inheriting its dimensions, a Smart connector, and a handful of other features from the 2017 10.5" Pro.
Other differences include: a new, darker Space Gray color, the absence of a camera bump, and two speakers compared to the Pro's four. (Landscape stereo sound is a Pro-only feature.)
Compared to its Mini brother, it's pretty much just ... bigger.
iPads continue to be tough nuts to crack, so we raise the stakes—or rather, the iOpeners.
With their powers combined, plus some suction and slicing, we get into this fused display and start to lever it open.
Our first peek inside reveals an internal layout that's rather different from Airs past, featuring a central logic board—as seen in certain Pro iPads.
Tool used on this step:Battery Blocker$3.99
Safety first! This battery disconnection is definitely not as foolproof as the bracket in the iPad Mini 5.
It feels like the display cables are just too short to easily free the cable bracket, making for a thrilling balancing/unscrewing act.
The dual-celled 30.8 Wh battery is a little bigger than the 30.2 Wh Apple promised, taking after the 10.5" Pro, and a big upgrade from the 27.6 Wh battery in the Air 2.
If only it had also inherited the highly-coveted stretch-release adhesive pull tabs ... sigh.
With the 10.5-ification of this Air, the updated display gets Apple Pencil support—but only second-class, leaving the new Pencil 2 exclusively to the Pro line.
Responsible for turning your finger pokes into ones and zeroes, we have:
Likely Renesas (formerly Intersil) ISL24882B 8-Ch. TFT-LCD reference voltage generator w/ integrated EEPROM (seen in the 10.5" Pro)
Parade Technologies DP825 timing controller (previously seen in the 10.5" Pro)
Texas Instruments TPS65195 level shifter (seen in the Mini 5)
The size is similar, the Pencil support is similar, and the chips are similar to the 10.5" Pro. However, the Air is missing one notable Pro feature—the cool ProMotion 120 Hz display.
I guess it’s the Intersil in red that’s causing all the heat while using the Apple Pencil. Gets nice and warm in that bottom corner while taking notes etc.
Will iPad Pro 10.5” display fit and work on iPad Air 3?
In place of the 10.5" Pro's surround sound speakers, we find a large metal bracket and two posts built into the case.
These little metal mesas likely support the display and hold additional antennas in the LTE models.
While the Mini's front-facing camera got a significant upgrade, the Air's rear camera holds steady at 8 MP—meaning the Pro's 12 MP still reigns supreme in the 10.5" tablet photo arena.
We do away with a single screw and peel back a huge shield from the logic board, exposing that sweet silicon underneath.
Shields dispatched, we've got some
air-friedchips for you! -
Apple APL1W81 A12 Bionic SoC layered over 3 GB SK Hynix H9HKNNNDBMMUYR LPDDR4X RAM
Toshiba TSB3243V40755TWNA1 64 GB NAND flash
Apple 343S00281-A0 Power Management
Apple/Universal Scientific Industrial USI 339S00551 Wi-Fi/Bluetooth Module (as seen in the iPhone XS)
2x Broadcom BCM15900B0 touch screen controllers
Apple 343S00264-A0 power management IC
NXP Semiconductor SN100V NFC controller (likely)
Not to sound like a broken record, but your eyes don't deceive you! That Air 3 looks an awful lot like the 10.5" Pro!
A central logic board, dual-cell battery, Apple Pencil support, and Smart connector all say "Pro" to us—we're just missing the second set of speakers!
The Air 2 and the 10.5" Pro both have pretty miserable repairability scores. Could this tablet break the mold? Scroll down to find out!
- A single Phillips driver takes care of all the screws.
- Many components are modular and can be replaced independently, but the Lightning port is soldered to the logic board.
- Battery replacement is possible, but still unnecessarily difficult.
- Gobs of adhesive hold many parts and cables in place, complicating all repairs.
Final Thoughts
Repairability Score
(10 is easiest to repair)
26 Comments
Screen compatibility?
I am also curious about this
Can I ask? Lightning port uses USB2 or USB3 speed?
usb 3. see here it uses same 16 pins lightning port as pro 10.5 :D https://www.mobilesentrix.com/charging-p...
Well never mind. iPad came in and has usb2
what parts are interchangeable from the iPad pro 10.5 and the iPad Air 3 ? Screen, Battery, Chargerport ?
Double-sided Lightning port? (I’m giving up on Lightning; I now believe Apple has made the decision to not pursue Lightning as a long-term connector format, so I’d be surprised to see double-sided here (which could be nearly-as-capable as USB Type-C, pin-wise, minus the legacy USB2 channel).)
And, in your expert opinion, how difficult do you folks think it would have been for Apple to have architected this chassis (and the iPad mini 5 chassis) to support the use of both laminated AND non-laminated displays? I would greatly like Apple, at some point, to show that they’re designing simultaneously for the needs of education/low-cost buyers and “$500 tablet” buyers, differentiating by screen quality and repair cost. The iPad mini 5 chassis -looks- like it could fit the mini 3 non-laminated display within it, if the proper standoffs were milled in (weren’t milled out). IMHO, seeing that kind of “long term vision” of chassis reuse would be a good sign. (I hold out hope of seeing the iPad mini 5th gen mobo in the iPad 7th gen.)
yes the port is double side. seems the usb3 controller is integrate into the SOC this time around.
Another difference - my 10.5” pro has 4gb of ram vs 3gb in the air 3.
The screen connections look identical to pro 10.5”, are they interchangeable?
I broke my ipad air 3 screen. Can use the ipad pro 10.5 screen on the ipad air? Just the screen not the lcd.
Good evening could the nand Flash memory be upgradable like to 512gb?
Hi Jorge,
As the memory is basically chips on the logic board, it is not possible to upgrade it. You can try to replace the entire logic board with one that has a higher capacity pre-installed.
does it have a digitizer
Anyone aware of the multiple issues with Apple Pencil ( 1st. Generation) connecting with the iPad Air? I’m on my second brand new one in 2 weeks and unable to use the pencil. It will not even register/pair with the air. Software updated, fully charged both iPad and pencil. Tried my daughters pencil and it wouldn’t connect/ pair with either of the airs. Both my pencil and my daughters work perfectly with a 12.9 “ iPad Pro and a 9.7 “ iPad Pro without issues. Any response would be helpful. I’m going to ask Apple for a complete refund…
I’ve found that I have a pressure point (white spot in the screen) and I’ve used multiple methods to remove it, with no success. Places like ubreakifix wanted $250 to just replace the screen, and it’s past warranty to try and take it to Apple to replace.
Russell, that pressure point was a known issue of the 10.5” iPad Pros that this iPad Air is based on, it’s a shame Apple didn’t fix it with this update. Some people have had luck getting a replacement from Apple even out of warranty since it’s a manufacturer defect. If that doesn’t work, you can pay Apple for a battery replacement (usually $99) and they’ll give you a new (refurbished) device since their techs don’t do iPad battery swaps! Not a perfect solution, but I hope this helps. I had the same thing happen to my iPad Pro.
Anyone else knows if the white spot issue has a tendency to get worst overtime? Someone on the apple forum noticed it happens near the are of the logic board where some conector are placed, raising the possibility of a heated related damage to the screen. Since the size of the logic board is limited (as well as the size of such connectors) will the problem get worst over time?
Do you have a kit for replacing the main screen on an iPad Air 3? If so, do you have a walk through showing how to change said screen.
Yes, that's here: iPad Air 3 Screen Replacement. You'll find the links to the parts you need on the top right of the guide :-)
