My Problem
I was having weak wifi signals all the time as well as my gps navigation did not work
My Fix
got the parts from fixit , had watched few videos on youtube as well as step by step instructions from fixit which was very helpful. The repair was mostly smooth , the only glitch came in when putting the logic board back on the phone. step before adding the metal shields over
My Advice
The logic board is very delicate and needs to be placed very carefully, the lego connector strips from various parts come in the way and needs to be maneuvered carefully. Apart from that there is one screw which goes to the metal frame which is little tricky while tightening back. Other than it is pretty straight forward. Just have to make sure the connectors are all in place in each
One Comment
Hello. In the title you mentioned you replaced the gps antenna and the wifi antenna. Did the antenna flex cable fix both the wifi and gps issues ? I am having similar wifi issues and my gps navigation will not follow me or give turn by turn instructions.
Thanks.
BTO - Reply
