My Problem
Quick battery discharge
My Fix
Good replacement, but would not charge past 1%. There is a small insulator underneath the battery plate cover. If that isn't perfectly placed over the battery terminal then when you charge the battery it will short. It will result in your phone not able to charge above 1%. I added a small piece of electrical tape underneath the battery plate and then the battery charged as expected.
My Advice
Make sure the battery plate doesn't contact the terminal post or the battery will short when charged. Add a small piece of electrical tape under the battery plate to ensure you insulate the post from the plate..
0 Comments
