My Problem
Battery capcity low
My Fix
Mostly okay.
My Advice
Everything went okay, except aligning the battery as instructed put the battery connector in slightly the wrong place. This meant I had to force the connector a bit, and then it sat proud of everything else. This put a pressure point on the back of the screen, causing a blue spot on the screen once assembled. Since the adhesive strips were already on there, there was no going back.
I HIGHLY RECOMMEND a dry test fit of battery placement BEFORE applying the adhesive strips and request that a dry fit be added to the instructions.
0 Comments
