My Problem
After 2 years, the battery was pretty bad.
My Fix
Aside from removing the battery adhesive tabs, the replacement was extremely straightforward.
My Advice
1) Take off the screen assembly. It may seem fiddly, but it's not worth damaging those special components.
2) The battery pull-tabs are pulled from the center of the bottom edge to the side of the bottom edge and THEN all the way to the top of the battery (like an L on the left side). The instructions aren't perfectly clear on that point, so know that the battery tabs don't end until you're at the top end of the battery.
0 Comments
