My Problem
Cracked digitizer
My Fix
Good with the exception of the glass chipping away around the edges as I separated the old digitizer from the casing. Worst part is getting the old glass off.
My Advice
Take your time with this entire repair and everything will be ok. Be sure to tape up cracked screens but you may need to pull the tape up in certain areas to use the suction cup. Also be sure to clean all old adhesive before applying the new digitizer.
0 Comments
