« Back to All Stories
Replace a swollen, old battery
franktamborello -
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Battery Replacement
10 - 45 minutes
Moderate
My Problem
The old battery had swollen enough to push on the trackpad.
My Fix
The repair went exactly as advertised!
My Advice
Because the old battery was swollen, it pushed against the bottom case panel with enough force to throw the tiny screws some distance as I loosened them! If your old battery is swollen, take care to apply some pressure to the bottom panel and contain the screw you're removing until you've completely removed the screw.
Spudger Image
Spudger
$3.99
Phillips #00 Screwdriver Image
$5.49
P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery Image
$5.49
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery Image
$94.99
0 Comments
