iMac Intel 21.5" Mid 2011 Dual Hard Drive Kit
  • iMac Intel 21.5" Mid 2011 Dual Hard Drive Kit / Upgrade Bundle
  • iMac Intel 21.5" Mid 2011 Dual Hard Drive Kit / Part Only
$19.99
$19.99
We'll send a message when the product is back in stock.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Product Details
Description
Description
Hack a second Hard Drive into your 21.5" Intel iMac
  • Custom kit exploits an extra SATA port unused on the iMac logic board.
  • Use our easy to follow guide to do the job.
  • Mount your drive inside the case, out of sight completely.
  • This kit does not include a Hard Drive.
Fix Kit includes:
Part Only includes:
  • SATA data cable
  • SATA power splitter
  • Custom-cut 3M mounting tape
If you're the owner of a 21.5" iMac, you understand that bigger is not always better. Your iMac can do nearly everything its 27" big-brother can, and you've got at least five extra Benjamins still in your wallet. If you want your iMac to really fly, the biggest bang for your buck is to boot using a blazing-fast SSD. Since a 1 TB SSD might cost more than your iMac, we've got a solution for those who lack unlimited budgets.
It will work with all processor speeds, regardless of whether Apple offers the additional SSD option for your machine. And unlike other kits, our product does not require permanently removing your optical drive. You'll have two storage drives as well as a functioning optical drive.
Install Video
Compatibility
iMac Intel 21.5" EMC 2428
2.5 GHz (Mid 2011)
2.7 GHz (Mid 2011)
2.8 GHz (Mid 2011)
Repair Stories
User avatar
Jason Whong's Story Photo #1197517
Jason Whong's Story Photo #1197518
Jason Whong's Story Photo #1197516
My Problem
The internal HD had been slow for a while, so I thought I would add an SSD.
My Fix
The first time I opened it, I was afraid I broke it, because the vertical sync cable didn't look like it was connected to anything and was in fact missing its connector. Also, the video cable popped right out of the motherboa . . .
User avatar
Andrew Posani's Story Photo #744784
Andrew Posani's Story Photo #744786
Andrew Posani's Story Photo #744785
My Problem
I wanted to add more space to my iMac so I could use it more so as a media server instead of having everything on external hard drives. Having everything in one spot makes it faster to browse and easier for me.
My Fix
Everything started out good. Ordered the iMac hard drive kit from iFixit so had all the ne . . .
User avatar
justincarver's Story Photo #1373321
My Problem
Slow performance using the original 1TB 7200 RPM hard disk. Installed a 500 GB WD Blue SSD to work alongside the HDD (custom Fusion Drive).
My Fix
Process was simple. Remove screen, remove superdrive, remove mainboard, install SSD and necessary cables, and reinstall. No issues whatsoever.
My Advice
Take your time, tak . . .
User avatar
cjlemos's Story Photo #513092
My Problem
My Imac old HD was full and slow.
My Fix
Just folowed the repair guide. Not a single problem. Every thing worked fine. I also upgraded memory from 8 to 16 GB. Now My Imac is runing even faster than when it was brand new.
My Advice
make sure to view the video first.
User avatar
My Problem
My 2011 iMac was booting slowly and needed more disk space. I figured a new SSD would help it to run faster so I could reliably use it for music recording / production again.
My Fix
Everything went fine! I was scared to take the screen off but it turned out to be much easier than I expected. As long as you . . .
User avatar
My Problem
I replaced the (long-time broken) Optical Drive with an SSD, using a mounting from a previous upgrade. The total time was not very long, but I had to interrupt progress fron time-to-time. The Repair Guide mentions to tape back the loose cables before re-inserting the logic board -- OH YES! It was . . .
User avatar
My Problem
Nothing particularly the matter, I just wanted an SSD for faster load times.
My Fix
The repair went well. I was a little concerned I was going to mess something up, as I always am, and that my CPU wouldn't boot when I was done. Everything is so tightly packed into a mac, it makes for some pretty intense ins . . .
User avatar
My Problem
My iMac was getting a little long in the tooth, and after using a MacBook Air with an SSD, I got spoiled by the speed of that little computer. So after researching a bit, I decided to take a plunge on creating my own fusion drive using the existing 500 GB hard drive and a 120 GB SSD I picked up on . . .
User avatar
My Problem
My iMac was over 3 years old. Has a decent i5 and graphics card but a old school HDD. I use my machine for audio podcast production so I was worried that it wouldn't keep up with my production goals.
My Fix
Amazing! The guide was perfect. Easy to follow with pictures that we exactly what I needed during . . .
User avatar
My Problem
IMac 21.5" Mid 2011 running slow due to fullish 500GB original HD. Wanted SSD for speed, big HDD for storage. Apple "Fusion Drive" capability automatically manage this.
My Fix
iFixit kit and instructions are great. Very clear. Just work slowly. Tape down the wires as you unplug them - especially from th . . .
Show more
