iMac 24" 2.8 GHz (EMC No. 2211) Hard Drive Enclosures
Grab a tool kit for your iMac 24" 2.8 GHz (EMC No. 2211) model and fix a broken computer!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with iMac 24" 2.8 GHz (EMC No. 2211):
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
iMac Service Wedge
Foam support wedge for holding heavy computers in place.
1 TB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 1050 GB Unformatted
500 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 525 GB Unformatted
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
iMac Intel 20" and 24" (Mid 2007-Early 2009) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 20" and 24" Mid 2007-Early 2009 with this SSD upgrade bundle.
250 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 275 GB Unformatted
PC2-6400 2 GB RAM Chip
RAM Upgrade / 2 GB / PC2-6400 800MHz / Low Profile / 200 pin
1 TB 7200 RPM 3.5" Hard Drive
Replace or upgrade the hard drive in your compatible iMac with this part.
Device Info
This update of the iMac increased processor speed within the aluminum shell.
Need more memory? Two PC2-6400 2 GB RAM chips will max out your memory at 4 GB. A 2 TB SATA hard drive will top off your storage capacity.
Select your category below or browse all compatible parts to find what you need to fix your machine!
