MacBook Unibody (A1342) MagSafe DC-In Board
  • MacBook Unibody (A1342) MagSafe DC-In Board
$39.99
$39.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged MagSafe DC-in board for your Model A1342 MacBook Unibody with this part. This assembly connects the AC wall adapter power to the logic board and is compatible with all Unibody (Model A1342) 13" MacBooks.
Compatibility
Repair Stories
My Problem
Problem with DC input connection
My Fix
Easy to repair with internet repair video. Part was easy to install and macbook rolls fine again :)
My Advice
no
My Problem
I bought a new battery off Amazon when I got my MacBook on eBay and the battery suddenly stopped charging and would shut off immediately when unplugged.
My Fix
Very quick and easy replacement! Didn't fix the issue but have a new battery on the way from you all.
My Advice
To get the flat ribbon cable back in, uses pie . . .
My Problem
MagSafe Adapter Hot When Charging Battery, Running On Power Adapter 100% Charge Indicated Until MacBook Shuts Off From Low Battery, Difficult Getting Battery To Charge.
My Fix
Once I ordered the parts from iFixit and received them, along with an $8 minibit screwdriver set from harbor freight, I enlisted the . . .
My Problem
Broken MagSafe board
My Fix
Went good
My Advice
Bought part from amazon, it was either broken or a fake; it did not work. Bought part from ifixit and it fit better and actually worked. Fixed the laptop.
My Problem
battery was dead and magsafe board failed
My Fix
everything was great, i had 1 screw stripped from a previous repair but it wasn't too much of an issue and i broke 1 speaker connector , but that speaker was already blown and will be replaced once i can afford it.
My Advice
be very gentle with the speaker connectors, t . . .
My Problem
My wife's Macbook stopped charging. After a short troubleshooting I figured out that the Magsafe connector was at fault. Also, as the laptop was mostly used on soft covered surfaces, cooling was poor, causing some overheating of the lower case, hence causing bubbling of the non slippery rubberized s . . .
My Problem
My mac did not charge, and would not boot up when the battery was disconnected.
My Fix
I browsed the web and found out that there was a part called the magsafe board betweeen the charger and the other components. I followed IFixit instructions and replaced the magsafe board.
The only problem I have discov . . .
My Problem
il mio magsafe era bruciato da un alimentatore difettoso e non si accendenva più il macbook
My Fix
bene la guida è dettagliata e facile da seguire
My Advice
Seguite la guida!
My Problem
Mag safe on MacBook was damaged by my kids. No way to power the computer. Repair store said it would cost $275 to have it fixed. This was an older MacBook (2009) and I didnt want to sink that much money in it.
My Fix
Repair went great. Instructions were exactly right and easy to follow. Highly recommend. M . . .
My Problem
My power cable connector kept overheating and melting the inside of the connector. Eventually figured out that the MagSafe board needed replacing.
My Fix
Smooth, no problem - followed a tip from a user to skip from step 6 to step 18, that saved a lot of work and it went fine.
My Advice
When disconnecting the display . . .
Show more
