MacBook Unibody (A1278) Replacement Battery
  • MacBook Unibody (A1278) Replacement Battery
  • 360°
360
New battery guaranteed at capacity greater than 3960 mAh.
$99.99
$99.99
We'll send a message when the product is back in stock.
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Product Details
Description
Description
Replace a dead or otherwise malfunctioning battery in your MacBook Unibody (Model A1278) laptop computer with an aftermarket replacement battery.
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Note
This part only works in the A1278 MacBook. It will not work in a A1278 MacBook Pro even though the model number is the same. This is an aftermarket battery and NOT an Apple OEM battery.
Warning
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Compatibility
Repair Stories
My Problem
The old battery was OLD... and not holding a charge.
My Fix
Easy. This model (2008 aluminum) is designed for having the user replace the battery.
My Advice
None needed...
My Problem
Old battery (original) had gotten swollen (interfered with trackpad) and it didn't hold a charge.
My Fix
I opened the back (push on the simple lever/tab, pull off the panel) and inserted the new battery. I replaced the panel and it was done. Easy!
Battery was partly charged. I let it charge fully overnigh . . .
My Problem
La batterie d'origine était fatiguée après huit ans devons et loyaux services
My Fix
Très facilement, ce MacBook a été bien conçu sur ce plan en tous les cas.
My Advice
Je ne peu que remercier ifixit pour ses services de qualité.
My Problem
My cat walked on my Mac-book and it crashed on the floor.
The screen broke in the meddle and the Apple store didn't want to repair it because too old (for them).
My Fix
I fixed it easily following the photo-sequence of iFixit web site,
However I suggest two improvements:
1. It's not necessary to use the Hea . . .
My Problem
Declining battery power for years. I've had this Macbook for almost seven years, and one battery charge would last 45 minutes.
My Fix
The repair went so easily, I wish I'd done it earlier. It took 4-5 minutes tops.
My Advice
If your Macbook A1278 battery needs to be replaced, I would go ahead and do it. It's so easy.
My Problem
My battery was dying. After 6 years of loyal service.
My Fix
So easy. The early MacBook made it easy for the battery to be replaced. Happy and I think this MacBook can last me one or two more years. Time to start saving up for the next one =)
My Advice
Take care of your electronics equipment (name it!). It'll save you . . .
My Problem
My Macbook unibody alu, late 2008, has a good 6 year on the back. A few years ago, i changes the HDD and screen unit, since it was going bad. Now the fan was started to sound like a jet engine and it was running slow, plus the battery only lasted an our.
My Fix
I Ordered a new SSD, plus a dummy for my Supe . . .
My Problem
Basically, because I was bored with the old system so I upgraded everything and I finally had the time - literally jumped from snow leopard to yosemite! It started with installing higher ram then figured out it was easy enough to install not just a new hard drive but a dual one. Thanks to you guys w . . .
My Problem
Cracked screen of course
My Fix
The repair went well all the way until I tried to use the home button on the new display assembly only to find that it wouldn't depress, which made me depressed.
So I opened it up and the button would depress. Clicked it back in and it would work with needing to be depressed . . .
My Problem
Battery needed to be replaced (out dated)
My Fix
very well
My Advice
if you live in the us buy from Amazon.com. I live in Saudi and It was the only way to import.
Show more
