MacBook Santa Rosa/Penryn Fan
  • MacBook Santa Rosa/Penryn Fan
$29.99
$29.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replacing a broken or noisy fan?
Includes fan and surrounding metal bracket.
Compatibility
MacBook Core 2 Duo
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
Repair Stories
User avatar
My Problem
My daughter's Mac sounded like a lawnmower when it got hot.
My Fix
Repair was relatively straightforward following the guide on iFixit.
My Advice
Some of the steps refer to a #0 Philips but a smaller screwdriver works better. Watch out for the screws behind the memory cover. When replacing, use light pressure to get t . . .
User avatar
My Problem
My hard drive finally went up after 8 years. When I opened up my Mac to clean out dust, I noticed my fan seemed off... Considering it went from loud to silent overnight. I tested it and it was also in need of replacement, so I ordered the part.
My Fix
Easy as pie. The guide is 100% accurate and the screws a . . .
User avatar
My Problem
La ventola, oltre a essere rumorosa, iniziava a perdere giri e le temperature salivano troppo; dopo anni di servizio era arrivata al capolinea.
My Fix
Dopo la sostituzione il computer è tornato silenzioso e le temperature sono nuovamente sotto controllo.
La prima ventola che mi hanno spedito si è rivelata . . .
User avatar
My Problem
LAPTOP OVER HEATING AND SHUTTING DOWN, fan not blowing
My Fix
I ordered part from Ifixit. I had previously replaced my keypad with new one from IFIXIT and directions I found on youtube. So I had and idea on how to disassemble. I took my laptop to a computer repair store, he said not busy at all. Big mistak . . .
User avatar
My Problem
The fan in my 2009 Macbook broke down; we went to iCentre here in The Netherlands who claimed the main board broke down; yes, for EUR 1100,- we could replace it. AND .. they had a nice action right that moment for a new Macbook Pro blah blah blah…
Ofcourse we did not go for their stories and w . . .
User avatar
My Problem
My MacBook Santa Rosa was heating and the noise of the fan was too loud.
My Fix
I've change thermal paste and fan with a new one. The fan replacement wasn't necessary, the old one was in good shape. The thermal paste replacement has reduced the heating.
My Advice
Do not replace the fan heaven if you think your MacBook . . .
User avatar
My Problem
So the problem was not even the fan, it was the inverter, SO while changing the inverter i thought it would be a good idea to clean out the dust in the fan and under the board. Turns out an air compressor at max speed will destroy a macbook fan, so while i was fixing one thing, i broke another, So i . . .
User avatar
My Problem
making a loud noise
My Fix
followed the instructions on the guide and it was very straightforward
My Advice
I taped each set of screws onto a piece of printer paper and labeled them as i went, which made them easy to keep track of.
Show more
