MacBook Pro 15" Unibody (Early 2011/Late 2011) Display Assembly
Our used options may have as many as three (3) dead pixels, per industry standard and may have cosmetic blemishes to varying degrees. Also, some parts may have outer housing that have been refurbished to remove dents and/or scratches. These refurbished parts may have a slightly different finish than an original part. The parts are fully functional.
$299.99
$299.99
We'll send a message when the product is back in stock.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Product Details
Features
Features
Is your Display old or overused? Replace it!
Glossy surfaces are wonderful for their ability to reflect light, repel water, and frighten stilt-walkers. Ward off lanky pedestrians today with our MacBook Pro 15" Unibody (Early 2011) display assembly.
This complete display assembly includes the FaceTime HD camera.
Note: The high resolution glossy or anti-glare displays are custom-to-order options. If you did not select this upgrade when purchasing your machine, you have the standard glossy display.
Compatibility
Repair Stories
User avatar
My Problem
Bought a macbook pro as a refurbished device with a Matt screen, and the colors where washed out.
My Fix
Pretty easy
My Advice
When putting the new screen in the alignment for the hinges are a little bit tricky just some patience and you'll be golden
User avatar
My Problem
Screen glass, display and top cover damaged due hard object dropping onto my wife's computer when in closed position.
My Fix
Repair went OK until having to remove cable display data cable retainer from the upper case. The retaining screw could not be removed however hard I tried - the result being that th . . .
