Fix Your Stuff
Right to Repair
Store
Parts Mac MacBook MacBook Core 2 Duo Logic Boards
Store
Grab a toolkit for your MacBook Core 2 Duo model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Don't know your model? ID Your Mac
MacBook Core 2 Duo 2.1 GHz Logic Board
Replace a 2.1 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage....
$74.99
MacBook Core 2 Duo 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Por...
$189.99
MacBook (Early 2009) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the Early 2009 MacBook. Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out. ...
$299.99
MacBook (Mid 2009) 2.13 GHz Logic Board
Replace a 2.13 GHz logic board (motherboard) compatible with the Mid 2009 MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini-D...
From $224.99
MacBook Core 2 Duo 1.83 GHz Logic Board / White
Replace a 1.83 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage...
$99.99
MacBook Core 2 Duo 2 GHz (Energy Star) Logic Board
Replace a 2 GHz Energy Star logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or wat...
$149.99
MacBook Core 2 Duo 2.16 GHz (non-Energy Star) Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage...
$129.99
MacBook 2 GHz Santa Rosa Logic Board
Replace a 2 GHz Santa Rosa logic board (motherboard) compatible with the MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini DV...
$29.99
MacBook Core 2 Duo 2.16 GHz (Energy Star) Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Included Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 ...
$149.99
Showing products 1 - 9 of 9
Device Info
The Core 2 Duo MacBooks feature beefier processors, thanks to the Core 2 Duo chipset. The Santa Rosa versions feature faster bus speeds and a graphics processor upgrade. A comprehensive change to a new type of logic board connector makes this version largely incompatible with prior MacBook versions. Penryn versions feature faster processor speeds. For the Early and Mid 2009 models, Apple introduced optical drives with SATA interface. Bluetooth has also been updated to version 2.1.
The 500 GB 7200 RPM SATA hard drive will max out your storage.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your model above or browse all compatible parts to find what you need to fix your laptop!
