Parts Mac MacBook Air 13" Original Rubber Feet
Store
Don't know your model? ID Your Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9.99
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
From $39.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
$7.99
MacBook Air (Original) Upper Case with Keyboard
The upper case includes the keyboard, palmrest area, trackpad, power button, and trackpad.
From $17.99
MacBook Air (Original) Hard Drive Cable
Replace a torn or corroded cable connecting the hard drive to the logic board.
$24.99
MacBook Air Logic Board Bracket
This bracket clamps the Airport/Bluetooth cable and trackpad control cable to the logic board.
MacBook Air 13" (Original-Mid 2009) Display Assembly / A-Stock
The display assembly includes the 1280x800 pixel 13.3" LCD screen, display cover, bezel, iSight Camera, clutch hinges, Wi-Fi antenna, iSight, and display data cables.
$349.99
Showing products 1 - 10 of 28
Device Info
The MacBook Air only has a few user upgrade possibilities. You can, however, swap out a bad battery with a replacement battery using our battery repair guide. With our hard drive replacement guide, you can increase your storage space by replacing your 80 GB 1.8" hard drive with a larger 120 GB 1.8" hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
We offer parts for every need to resurrect your machine, from case components and cables to displays and logic boards. Select your category below or browse all compatible parts to find what you need to fix your laptop!
