MacBook Air 13" Original Logic Boards
Grab a toolkit for your MacBook Air 13" Original model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook Air 13" Original:
MacBook Air (Original) 1.6 GHz Logic Board
Replace a broken or damaged 1.6 GHz logic board in your Original MacBook Air 13" with this part.
MacBook Air 1.8 GHz (Original) Logic Board
The 1.8 GHz main circuit board assembly includes 2 GB of RAM.
MacBook Air Logic Board Bracket
This bracket clamps the Airport/Bluetooth cable and trackpad control cable to the logic board.
MacBook Air (Original) Processor Clamp
This bracket clamps the heat sink onto the main processor.
Device Info
The MacBook Air only has a few user upgrade possibilities. You can, however, swap out a bad battery with a replacement battery using our battery repair guide. With our hard drive replacement guide, you can increase your storage space by replacing your 80 GB 1.8" hard drive with a larger 120 GB 1.8" hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
We offer parts for every need to resurrect your machine, from case components and cables to displays and logic boards. Select your category below or browse all compatible parts to find what you need to fix your laptop!
