MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
$39.99
$39.99
Product Details
Description
Description
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
Part Assembly Includes
  • Fan
  • Attached Heat Sink
Compatibility
Compatibility
  • 1.6 or 1.8 GHz Original MacBook Airs
Specifications
Specifications
Part #:
922-8316
Install Video
Compatibility
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
Repair Stories
User avatar
My Problem
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
My Fix
Changed the fan. Cleaned the inside of the laptop from dust…
My Advice
Clean the inside at least twice a year…
User avatar
My Problem
Existing fan was loud
My Fix
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
My Advice
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
User avatar
My Problem
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
User avatar
My Problem
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
My Fix
The repair took abo . . .
Show more
