MacBook 13" Mid 2009 Case Components
Grab a toolkit for your MacBook 13" Mid 2009 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook 13" Mid 2009:
MacBook Front Display Bezel
Front Display Bezel
MacBook Memory Cover
Replace a bent or missing L-shaped metal cover for the RAM compartment in a MacBook laptop.
MacBook Santa Rosa/Penryn Upper Case with Keyboard
Replace an upper case, keyboard, trackpad, trackpad cable, and power button compatible with the MacBook model laptop. Part #922-9550, 922-8264, 922-8265, 661-5075, 661-50...
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
LCD mount including airport antenna cables.
MacBook Santa Rosa/Penryn Left Dust Guard
Left Dust Guard
MacBook Santa Rosa/Penryn Right Dust Guard
Right Dust Guard
MacBook Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Clutch Cover
Replace a damaged or missing clutch cover for a MacBook laptop.
MacBook (Early/Mid 2009) Lower Case
Replace a scratched-up lower case
MacBook Optical Drive Bezel
Replaces warped or broken optical drive bezel
Device Info
Apple introduced the Mid 2009 MacBook with a small speed bump and a redesigned heat sink (with no integrated thermal sensors).
The MacBook 13" 2.13 GHz (Mid 2009) laptop can be upgraded to a hefty, yet agile 750 GB 7200 RPM SATA hard drive Upgrade Kit. A total of 8 GB of PC2-6400 or PC2-5300 RAM can be installed, using two 4 GB chips.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
