MacBook 13" Core 2 Duo Late 2006 Case Components
Grab a toolkit for your MacBook 13" Core 2 Duo Late 2006 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parts that work with MacBook 13" Core 2 Duo Late 2006:
MacBook Upper Case with Keyboard (Black)
Replace an upper case compatible with MacBook model laptops. Includes keyboard, palmrest area, trackpad, trackpad cable, and power button.
MacBook Front Display Bezel
Front Display Bezel
MacBook Lower Case
Replace a scratched-up lower case
MacBook Memory Cover
Replace a bent or missing L-shaped metal cover for the RAM compartment in a MacBook laptop.
MacBook Left Dust Guard
Left Dust Guard
MacBook Right Dust Guard
Right Dust Guard
MacBook Santa Rosa/Penryn Upper Case with Keyboard
Replace an upper case, keyboard, trackpad, trackpad cable, and power button compatible with the MacBook model laptop. Part #922-9550, 922-8264, 922-8265, 661-5075, 661-50...
MacBook Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Clutch Cover
Replace a damaged or missing clutch cover for a MacBook laptop.
MacBook Optical Drive Bezel
Replaces warped or broken optical drive bezel
Device Info
Good became even better with the addition of Intel's Core 2 Duo processor!
The MacBook 13" Core 2 Duo (Late 2006) can be upgraded to a total of 3 GB of memory using a 2 GB RAM chip and a 1 GB RAM chip. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage. The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. You can also upgrade the upper case to the Penryn/Santa Rosa version with the new keyboard layout (including iTunes controls)!
There is one main variation within this model. Your machine may be a Energy Star-equipped or non-Energy star version. This affects the battery connector and logic board. See photos and part descriptions on the non-Energy Star or Energy Star battery connector/sleep sensors for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
