Introduction
Prereq-only for detaching the display assembly.
Tool used on this step:Magnetic Project Mat$19.95
Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
Two 1.1 mm screws
One 1.5 mm screw
One 3.7 mm screw
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the three Y000 screws securing the display connector bracket:
Two 1.1 mm screws
One 1.5 mm screw
Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
