Logic Board Connectors
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Logic Board Connectors, Disconnect the logic board: step 1, image 1 of 2 Logic Board Connectors, Disconnect the logic board: step 1, image 2 of 2
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
  2. Logic Board Connectors: step 2, image 1 of 1
    Tool used on this step:
    Standoff Screwdriver for iPhones
    $5.49
    Buy
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. Logic Board Connectors: step 3, image 1 of 1
    • Remove the rear-facing camera bracket.
  4. Logic Board Connectors: step 4, image 1 of 2 Logic Board Connectors: step 4, image 2 of 2
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  5. Logic Board Connectors: step 5, image 1 of 1
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  6. Logic Board Connectors: step 6, image 1 of 1
    • Remove the upper cable bracket.
  7. Logic Board Connectors: step 7, image 1 of 2 Logic Board Connectors: step 7, image 2 of 2
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  8. Logic Board Connectors, Remove the top left antenna component: step 8, image 1 of 1
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  9. Logic Board Connectors: step 9, image 1 of 1
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  10. Logic Board Connectors: step 10, image 1 of 1
    • Remove the antenna component.
  11. Logic Board Connectors, Remove the top left grounding clip: step 11, image 1 of 1
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  12. Logic Board Connectors: step 12, image 1 of 1
    • Remove the grounding clip.
  13. Logic Board Connectors, Unscrew the logic board: step 13, image 1 of 1
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  14. Logic Board Connectors: step 14, image 1 of 2 Logic Board Connectors: step 14, image 2 of 2
    Buy
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  15. Logic Board Connectors: step 15, image 1 of 2 Logic Board Connectors: step 15, image 2 of 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
Arthur Shi
254,121 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,299 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 220
