This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
学习了解如何更换iPhone 6 Plus的屏幕组件。 此组件已安装配有前置摄像头,听筒和传感器电缆,非常便于维修替换。
您所需要做的就是拆除旧屏幕组件总成,把Home按键和新屏幕组件安装到手机上,以确保Touch ID功能(指纹识别)能够继续使用。
Video Overview
如果您的手机显示屏已经碎裂,请避免屏幕进一步的破碎,并且当您用胶带粘贴屏幕玻璃以维修手机时,请避免身体部位受伤。
使用透明胶带交替重叠粘贴,完整地覆盖住手机的屏幕。
如果屏幕玻璃的碎裂导致接下来的步骤中的吸盘难以吸在屏幕上,请尝试使用黏度较高的胶带(如粘水管用的胶带)折叠成一个把手,来提起屏幕。
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
请按本指南逆序步骤重新组装你的设备。
请按本指南逆序步骤重新组装你的设备。
747 other people completed this guide.
Special thanks to these translators:
80%
These translators are helping us fix the world! Want to contribute?
Start translating ›
96 Comments
I have original home screen button, but the panel and home button cable was part of what was damaged on the phone. With that in mind will it still work with original home screen button, but replacement panel?
This is a tough one. I do not know that you'll be able to salvage the Touch ID functionality of the home button with the connector being damaged. You may need to purchase iPhone 6 and 6 Plus Home Button Assembly and iPhone 6 and 6 Plus Home Button Gasket. This will no longer retain the Touch ID functionality though.
I will be testing this out myself as soon a I get a new touchID cable/along with the LCD Panel. I did a screen replacement, all went well and works great, however I punctured the TouchID cable when prying it off of the old display.
I ordered a new cable with the panel, as I understand it as long as you have the ORIGINAL TouchID assembly which I do, after replacing the cable it should work!
Instructions are incomplete ! You also have to remove the aluminum plate and the rear camera/speaker assembly.
Also, my touch ID does not work anymore :/ nothing was damaged and plug is connected. Resetting the phone made no difference.
Why would it not work if I used the same Home Button and logic board?
hey having the same problem with my touch id.. did you ever find a solution?
