Introduction
Prerequisite for removing the battery after the logic board.
Insert the tip of a spudger into the hole in the battery adhesive tab near the headphone jack.
Lift the tab up slightly and use the spudger to unfold the tab from its recess.
Pull the battery adhesive tab straight up from the phone.
Cut the black battery adhesive tab between the two white adhesive strips, separating them.
Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60ยบ angle or less.
Repeat to remove the second adhesive strip.
If you removed both strips successfully, skip the next two steps.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Flip the iPhone back over and insert a plastic card between the case side of the battery and the rear case.
Press the card in farther to break up the adhesive behind the battery.
