Introduction
Go to step 1 ↓Follow this guide to replace a broken or cracked back glass on an iPhone 18 Pro.
The back glass includes the wireless charging unit. If you're having issues with wireless charging, you may need to replace the back glass.
Note: You'll need replacement back glass adhesive to complete this repair.
Tools
Spudger4.9
Unplug all cables from your phone.
Hold the power and either volume button and slide to power off your phone.
Tool used on this step:iFixit Safety Glasses$7.95
Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
Make sure there's a single strip of tape (not overlapping) across the bottom edge, big enough for a suction cup to fit on.
Use a P2 pentalobe screwdriver to remove the two 7.5 mm‑long screws on either side of the charging port.
Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
Apply a suction handle to the bottom edge of the back glass, as close to the edge as possible.
Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
Insert the tip of an opening pick into the gap you just created.
Slide the opening pick around the perimeter of the back glass to separate all the adhesive securing it.
Flip the back glass over the left edge and use the suction handle to prop it up.
Use a tri‑point Y000 screwdriver to remove the 1.2 mm‑long screw securing the wireless charging connector cover.
Use the point of a spudger to pry up and disconnect the wireless charging press connector.
Tool used on this step:Tweezers$4.99
Use blunt-nose tweezers or your fingers to remove large pieces of adhesive from the frame.
Use a spudger to scrape the adhesive residue off the frame.
Without peeling any liners, lay the adhesive sheet over the frame to determine its proper orientation.
Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
Position the back glass so you can comfortably reconnect it.
Use your finger or a spudger to press and connect the back glass press connector onto the logic board.
Use a P2 pentalobe screwdriver to install the two 7.5 mm‑long screws on either side of the charging port.
If you have trouble with wireless charging, try running Apple’s Repair Assistant.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
