Shop the Holiday Gift Guide
iPhone 17 Screen Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
2
All Time:
48
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Screen Installation, Place the ambient light sensor: step 1, image 1 of 3 iPhone 17 Screen Installation, Place the ambient light sensor: step 1, image 2 of 3 iPhone 17 Screen Installation, Place the ambient light sensor: step 1, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Without letting the ambient light sensor adhesive touch the screen, use a pair of tweezers to hold the sensor above the back of the new screen.
      • Align the ambient light sensor with its recess in the back of the screen.
      • Use a spudger or your finger to press the ambient light sensor into its recess.
      • Lay the ambient light sensor cable down on the back of the screen.
      • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
      Ask FixBot
    2. iPhone 17 Screen Installation, Press the ambient light sensor: step 2, image 1 of 3 iPhone 17 Screen Installation, Press the ambient light sensor: step 2, image 2 of 3 iPhone 17 Screen Installation, Press the ambient light sensor: step 2, image 3 of 3
      • Use your finger to press down the ambient light sensor cable.
      Ask FixBot
    3. iPhone 17 Screen Installation, Install the ambient light sensor bracket: step 3, image 1 of 3 iPhone 17 Screen Installation, Install the ambient light sensor bracket: step 3, image 2 of 3 iPhone 17 Screen Installation, Install the ambient light sensor bracket: step 3, image 3 of 3
      • Use tweezers or your fingers to place the ambient light sensor bracket over the back of the sensor.
      • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
      Ask FixBot
    4. iPhone 17 Screen Installation, Remove the screen adhesive: step 4, image 1 of 3 iPhone 17 Screen Installation, Remove the screen adhesive: step 4, image 2 of 3 iPhone 17 Screen Installation, Remove the screen adhesive: step 4, image 3 of 3
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up the phone. Connect the screen, power on the phone, and make sure it works as expected. Power it back down, disconnect the screen, and continue reassembly.
      • The adhesive remaining on the phone's frame can be difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
      • Use a pair of tweezers to remove the adhesive around the entire perimeter of the phone.
      Ask FixBot
    5. iPhone 17 Screen Installation: step 5, image 1 of 3 iPhone 17 Screen Installation: step 5, image 2 of 3 iPhone 17 Screen Installation: step 5, image 3 of 3
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    6. iPhone 17 Screen Installation, Orient the adhesive: step 6, image 1 of 2 iPhone 17 Screen Installation, Orient the adhesive: step 6, image 2 of 2
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
      • Your adhesive may look slightly different.
      Ask FixBot
    7. iPhone 17 Screen Installation, Expose the bottom edge of the adhesive: step 7, image 1 of 2 iPhone 17 Screen Installation, Expose the bottom edge of the adhesive: step 7, image 2 of 2
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
      Ask FixBot
    8. iPhone 17 Screen Installation, Apply the adhesive: step 8, image 1 of 3 iPhone 17 Screen Installation, Apply the adhesive: step 8, image 2 of 3 iPhone 17 Screen Installation, Apply the adhesive: step 8, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, use your finger to press it down firmly along the bottom edge.
      Ask FixBot
    9. iPhone 17 Screen Installation: step 9, image 1 of 3 iPhone 17 Screen Installation: step 9, image 2 of 3 iPhone 17 Screen Installation: step 9, image 3 of 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Ask FixBot
    10. iPhone 17 Screen Installation, Press the adhesive into place: step 10, image 1 of 3 iPhone 17 Screen Installation, Press the adhesive into place: step 10, image 2 of 3 iPhone 17 Screen Installation, Press the adhesive into place: step 10, image 3 of 3
      • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
      • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
      • Be careful not to press on the camera, spring contacts, or other internal components.
      Ask FixBot
    11. iPhone 17 Screen Installation, Remove the top liner: step 11, image 1 of 3 iPhone 17 Screen Installation, Remove the top liner: step 11, image 2 of 3 iPhone 17 Screen Installation, Remove the top liner: step 11, image 3 of 3
      • Use the point of a spudger to lift the pull tab in the top‑right corner of the frame until you can grab it with your fingers.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
      • Peel back the top liner and remove it.
      Ask FixBot
    12. iPhone 17 Screen Installation: step 12, image 1 of 2 iPhone 17 Screen Installation: step 12, image 2 of 2
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the screen.
      Ask FixBot
    13. iPhone 17 Screen Installation, Prop up the screen: step 13, image 1 of 1
      • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
      Ask FixBot
    14. iPhone 17 Screen Installation, Connect the screen and front sensor: step 14, image 1 of 3 iPhone 17 Screen Installation, Connect the screen and front sensor: step 14, image 2 of 3 iPhone 17 Screen Installation, Connect the screen and front sensor: step 14, image 3 of 3
      • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
      Ask FixBot
    15. iPhone 17 Screen Installation, Cover the connectors: step 15, image 1 of 2 iPhone 17 Screen Installation, Cover the connectors: step 15, image 2 of 2
      • Use a pair of tweezers or your fingers to place the screen connector cover over the screen connector by inserting it at a slight downward angle to engage the hook, then laying the cover flat over the connector.
      Ask FixBot
    16. iPhone 17 Screen Installation: step 16, image 1 of 2 iPhone 17 Screen Installation: step 16, image 2 of 2
      • Use a pair of tweezers or your fingers to place the front sensor connector cover over the front sensor connector by inserting it at a 90‑degree angle to engage the hook, then laying the cover flat over the connector.
      Ask FixBot
    17. iPhone 17 Screen Installation, Install the cover screws: step 17, image 1 of 2 iPhone 17 Screen Installation, Install the cover screws: step 17, image 2 of 2
      • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
      Ask FixBot
    18. iPhone 17 Screen Installation, Remove the final adhesive liners: step 18, image 1 of 3 iPhone 17 Screen Installation, Remove the final adhesive liners: step 18, image 2 of 3 iPhone 17 Screen Installation, Remove the final adhesive liners: step 18, image 3 of 3
      • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
      • Use a pair of tweezers or your fingers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the iPhone.
      Ask FixBot
    19. iPhone 17 Screen Installation: step 19, image 1 of 3 iPhone 17 Screen Installation: step 19, image 2 of 3 iPhone 17 Screen Installation: step 19, image 3 of 3
      • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
      • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
      Ask FixBot
    20. iPhone 17 Screen Installation, Place the screen: step 20, image 1 of 2 iPhone 17 Screen Installation, Place the screen: step 20, image 2 of 2
      • Align the screen over the frame, then lower it into place.
      Ask FixBot
    21. iPhone 17 Screen Installation: step 21, image 1 of 2 iPhone 17 Screen Installation: step 21, image 2 of 2
      • Firmly press the top edge of the screen into the adhesive, then the bottom edge, until the screen is fully seated in the frame.
      Ask FixBot
    22. iPhone 17 Screen Installation, Heat the screen: step 22, image 1 of 2 iPhone 17 Screen Installation, Heat the screen: step 22, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • Firmly press around the perimeter of the screen.
      • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
      Ask FixBot
    23. iPhone 17 Screen Installation, Press the back glass: step 23, image 1 of 3 iPhone 17 Screen Installation, Press the back glass: step 23, image 2 of 3 iPhone 17 Screen Installation, Press the back glass: step 23, image 3 of 3
      • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
    24. iPhone 17 Screen Installation: step 24, image 1 of 2 iPhone 17 Screen Installation: step 24, image 2 of 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Ask FixBot
    25. iPhone 17 Screen Installation: step 25, image 1 of 3 iPhone 17 Screen Installation: step 25, image 2 of 3 iPhone 17 Screen Installation: step 25, image 3 of 3
      • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    26. iPhone 17 Screen Installation: step 26, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
Finish Line
Spencer Pennington
27,944 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 48
