Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Use the point of a spudger to pry up and disconnect the two USB-C port assembly press connectors (one's underneath the other) from the bottom-left corner of the logic board.
Remove the screws securing the USB-C port assembly:
Three 1.5 mm‑long JIS 00 screws
Two 1.7 mm‑long JIS 00 screws
One 1.3 mm‑long JIS 00 screw
One 1.2 mm‑long tri-point Y000 screw
Use a hair dryer or an iOpener to heat the entire USB-C port assembly until it's warm to the touch.
Slide the point of an opening pick between the microphone module (left of the USB-C port) and the bottom edge of the frame.
Pry gently to separate the microphone from the frame.
Slide the opening pick under the USB-C port assembly, near the center.
Slide the pick towards the right edge of the frame to separate the adhesive holding the assembly.
