iPhone 17 Pro Max USB-C Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Pro Max USB-C Removal, Remove the battery buffer: step 1, image 1 of 1
      • Use a hair dryer or an iOpener to heat the black plastic battery buffer until it's warm to the touch.
      Ask FixBot
    2. iPhone 17 Pro Max USB-C Removal: step 2, image 1 of 2 iPhone 17 Pro Max USB-C Removal: step 2, image 2 of 2
      • The large black graphite sheet (which looks like a black sticker) inside the frame is delicate. Be mindful not to scrape it with your spudger.
      • If you nick the graphite sheet, don't worry—it'll still function normally.
      • Use the flat end of your spudger to pry up one end of the battery buffer.
      • Grab the buffer with your fingers and slowly lift and remove it.
      Ask FixBot
    3. iPhone 17 Pro Max USB-C Removal, Disconnect the USB-C port assembly: step 3, image 1 of 3 iPhone 17 Pro Max USB-C Removal, Disconnect the USB-C port assembly: step 3, image 2 of 3 iPhone 17 Pro Max USB-C Removal, Disconnect the USB-C port assembly: step 3, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two USB-C press connectors (one's underneath the other) from the bottom-left corner of the logic board.
      Ask FixBot
    4. iPhone 17 Pro Max USB-C Removal, Remove the left logic board buffer: step 4, image 1 of 1
      • Use a JIS 00 screwdriver to remove the two 1.8 mm‑long screws securing the left logic board buffer.
      Ask FixBot
    5. iPhone 17 Pro Max USB-C Removal: step 5, image 1 of 1
      • Remove the left logic board buffer and store it for reassembly.
      Ask FixBot
    6. iPhone 17 Pro Max USB-C Removal, Remove the USB-C port assembly screws: step 6, image 1 of 2 iPhone 17 Pro Max USB-C Removal, Remove the USB-C port assembly screws: step 6, image 2 of 2
      • Remove the nine screws securing the USB-C port assembly:
      • Six 1.5 mm‑long JIS 00 screws
      • One 1.3 mm‑long JIS 00 screw
      • Two 1.2 mm‑long Y000 screws
      • If your iPhone doesn't have mmWave functionality, you may not have these screws.
      Ask FixBot
    7. iPhone 17 Pro Max USB-C Removal: step 7, image 1 of 1
      • Use a JIS 00 screwdriver to remove the 1.2 mm‑long screw securing the USB-C port assembly to the bottom left corner of the frame.
      Ask FixBot
    8. iPhone 17 Pro Max USB-C Removal: step 8, image 1 of 2 iPhone 17 Pro Max USB-C Removal: step 8, image 2 of 2
      • Use a JIS 00 screwdriver to remove the two 2.8 mm‑long screws securing the USB-C port to the bottom edge of the frame.
      Ask FixBot
    9. iPhone 17 Pro Max USB-C Removal: step 9, image 1 of 2 iPhone 17 Pro Max USB-C Removal: step 9, image 2 of 2
      • Use the point of a spudger to pry and separate the buffer strip covering the screw in the bottom right corner of the frame.
      Ask FixBot
    10. iPhone 17 Pro Max USB-C Removal: step 10, image 1 of 1
      • Use a JIS 00 screwdriver to remove the 1.2 mm‑long screw securing the USB-C port assembly to the right edge of the frame.
      Ask FixBot
    11. iPhone 17 Pro Max USB-C Removal, Soften the USB-C assembly adhesive: step 11, image 1 of 1
      • Use a hair dryer or an iOpener to heat the entire USB-C port assembly until it's warm to the touch.
      Ask FixBot
    12. iPhone 17 Pro Max USB-C Removal, Separate the microphone module: step 12, image 1 of 2 iPhone 17 Pro Max USB-C Removal, Separate the microphone module: step 12, image 2 of 2
      • Slide the point of an opening pick between the microphone module (left of the USB-C port) and the bottom edge of the frame.
      • Pry gently to separate the microphone from the frame.
      Ask FixBot
    13. iPhone 17 Pro Max USB-C Removal, Remove the USB-C port assembly: step 13, image 1 of 3 iPhone 17 Pro Max USB-C Removal, Remove the USB-C port assembly: step 13, image 2 of 3 iPhone 17 Pro Max USB-C Removal, Remove the USB-C port assembly: step 13, image 3 of 3
      • The large black graphite sheet inside the frame is delicate. Be very mindful not to tear it with your opening pick.
      • Slide the opening pick under the USB-C port assembly, near the center.
      • Slide the pick towards the right edge of the frame to separate the adhesive holding the assembly.
      Ask FixBot
    14. iPhone 17 Pro Max USB-C Removal: step 14, image 1 of 3 iPhone 17 Pro Max USB-C Removal: step 14, image 2 of 3 iPhone 17 Pro Max USB-C Removal: step 14, image 3 of 3
      • Grab the USB-C port assembly with your fingers and slowly pull it away from the frame to remove it.
      • If the USB-C port assembly feels stuck, check for any missed screws and separate any remaining adhesive.
      Ask FixBot
Arthur Shi
350,880 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 61
