iPhone 17 Battery Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Battery Removal, Before you begin: step 1, image 1 of 2 iPhone 17 Battery Removal, Before you begin: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 17 Battery Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 17 Battery Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 17 Battery Removal, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 17 Battery Removal, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 17 Battery Removal, Mark your opening picks: step 4, image 1 of 3 iPhone 17 Battery Removal, Mark your opening picks: step 4, image 2 of 3 iPhone 17 Battery Removal, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 17 Battery Removal, Heat the bottom edge: step 5, image 1 of 1
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
      Ask FixBot
    2. iPhone 17 Battery Removal, Insert an opening pick: step 6, image 1 of 3 iPhone 17 Battery Removal, Insert an opening pick: step 6, image 2 of 3 iPhone 17 Battery Removal, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 17 Battery Removal, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
      • Multiple spring contacts around the perimeter of the phone.
      Ask FixBot
    4. iPhone 17 Battery Removal, Heat the right edge: step 8, image 1 of 1
      • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    5. iPhone 17 Battery Removal, Separate the bottom right adhesive: step 9, image 1 of 3 iPhone 17 Battery Removal, Separate the bottom right adhesive: step 9, image 2 of 3 iPhone 17 Battery Removal, Separate the bottom right adhesive: step 9, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
      • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
      • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
      • You'll hear and feel the metal clip release as you pass it.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    6. iPhone 17 Battery Removal, Heat the left edge: step 10, image 1 of 1
      • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    7. iPhone 17 Battery Removal, Separate the left adhesive: step 11, image 1 of 3 iPhone 17 Battery Removal, Separate the left adhesive: step 11, image 2 of 3 iPhone 17 Battery Removal, Separate the left adhesive: step 11, image 3 of 3
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. iPhone 17 Battery Removal, Heat the top edge: step 12, image 1 of 1
      • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    9. iPhone 17 Battery Removal, Separate the top right adhesive: step 13, image 1 of 3 iPhone 17 Battery Removal, Separate the top right adhesive: step 13, image 2 of 3 iPhone 17 Battery Removal, Separate the top right adhesive: step 13, image 3 of 3
      • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
      • Continue sliding your pick around the top right corner until you reach the Action button.
      Ask FixBot
    10. iPhone 17 Battery Removal, Reposition the back glass: step 14, image 1 of 3 iPhone 17 Battery Removal, Reposition the back glass: step 14, image 2 of 3 iPhone 17 Battery Removal, Reposition the back glass: step 14, image 3 of 3
      • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • Swing open the back glass to the right of the phone to separate the remaining adhesive.
      • Support the back glass with a clean, sturdy object.
      • Remove the opening picks before continuing.
      Ask FixBot
    11. iPhone 17 Battery Removal, Remove the middle connector cover screws: step 15, image 1 of 2 iPhone 17 Battery Removal, Remove the middle connector cover screws: step 15, image 2 of 2
      • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
      Ask FixBot
    12. iPhone 17 Battery Removal, Remove the middle connector cover: step 16, image 1 of 3 iPhone 17 Battery Removal, Remove the middle connector cover: step 16, image 2 of 3 iPhone 17 Battery Removal, Remove the middle connector cover: step 16, image 3 of 3
      • Insert the point of a spudger in either cutout on the middle connector cover.
      • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
      • Remove the cover.
      Ask FixBot
    13. iPhone 17 Battery Removal, Disconnect the battery: step 17, image 1 of 2 iPhone 17 Battery Removal, Disconnect the battery: step 17, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    14. iPhone 17 Battery Removal, Disconnect the wireless charging coil: step 18, image 1 of 2 iPhone 17 Battery Removal, Disconnect the wireless charging coil: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
      Ask FixBot
    15. iPhone 17 Battery Removal, Remove the back glass: step 19, image 1 of 1
      • Lift the back glass off the frame and remove it.
      Ask FixBot
    1. iPhone 17 Battery Removal, Separate the silver tab: step 20, image 1 of 2 iPhone 17 Battery Removal, Separate the silver tab: step 20, image 2 of 2
      • Use an opening pick, or a clean fingernail, to peel up the silver tab at the bottom edge of the battery.
      Ask FixBot
    2. iPhone 17 Battery Removal, Assemble the VoltClip: step 21, image 1 of 2 iPhone 17 Battery Removal, Assemble the VoltClip: step 21, image 2 of 2
      • Plug the VoltClip's barrel connector into the USB-C elbow.
      • Don't connect the VoltClip to a power source just yet. The loose alligator clips may accidentally touch each other and cause an electrical short.
      Ask FixBot
    3. iPhone 17 Battery Removal, Attach the alligator clips: step 22, image 1 of 2 iPhone 17 Battery Removal, Attach the alligator clips: step 22, image 2 of 2
      • Attach the red alligator clip to the silver tab.
      Ask FixBot
    4. iPhone 17 Battery Removal: step 23, image 1 of 3 iPhone 17 Battery Removal: step 23, image 2 of 3 iPhone 17 Battery Removal: step 23, image 3 of 3
      • Attach the black alligator clip to the grounding screw.
      Ask FixBot
    5. iPhone 17 Battery Removal, Connect power to the VoltClip: step 24, image 1 of 3 iPhone 17 Battery Removal, Connect power to the VoltClip: step 24, image 2 of 3 iPhone 17 Battery Removal, Connect power to the VoltClip: step 24, image 3 of 3
      • Make sure the red alligator clip isn't touching any stray metallic surfaces.
      • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
      Ask FixBot
    6. iPhone 17 Battery Removal, Disconnect the VoltClip: step 25, image 1 of 3 iPhone 17 Battery Removal, Disconnect the VoltClip: step 25, image 2 of 3 iPhone 17 Battery Removal, Disconnect the VoltClip: step 25, image 3 of 3
      • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
      Ask FixBot
    7. iPhone 17 Battery Removal, Remove the battery: step 26, image 1 of 3 iPhone 17 Battery Removal, Remove the battery: step 26, image 2 of 3 iPhone 17 Battery Removal, Remove the battery: step 26, image 3 of 3
      • Your adhesive should be fully loosened at this point. If your battery doesn't budge during the step, reconnect the alligator clips for an additional minute and try again.
      • Grip the silver tab and lift the battery out of the frame.
      • Alternatively, you can use a suction handle to pull the battery out. If the battery doesn't come out easily, don't force it—repeat the previous step.
      Ask FixBot
After your repair, run Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
Alex Diaz-Kokaisl
250,018 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 161
