Shop the Holiday Gift Guide
iPhone 16 Pro Taptic Engine Removal
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
32
All Time:
276
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite guide to remove the Taptic Engine in an iPhone 16 Pro.
Tools
    1. iPhone 16 Pro Taptic Engine Removal, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Prepare the phone for disassembly: step 1, image 2 of 2
      • Before you begin:
      • Back up your data.
      • Discharge the phone's battery drain below 25%. A charged lithium‑ion battery can catch fire if accidentally damaged.
      • Unplug any cables, and remove all cases, covers, and accessories (like portable chargers).
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Pro Taptic Engine Removal, Cracked glass preparation: step 2, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Cracked glass preparation: step 2, image 2 of 2
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape on the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 16 Pro Taptic Engine Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro Taptic Engine Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro Taptic Engine Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too deep, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      • On all edges, keep the opening pick at least 2 mm deep to avoid putting pressure on the glass itself.
      Ask FixBot
    4. iPhone 16 Pro Taptic Engine Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
      Ask FixBot
    1. iPhone 16 Pro Taptic Engine Removal, Heat the bottom edge: step 5, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Heat the bottom edge: step 5, image 2 of 2
      • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's slightly too hot to touch.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    2. iPhone 16 Pro Taptic Engine Removal, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Pro Taptic Engine Removal, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Pro Taptic Engine Removal, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • If the back glass doesn't budge, reheat it and try again.
      • Insert the pick just far enough to sit fully beneath the glass.
      Ask FixBot
    3. iPhone 16 Pro Taptic Engine Removal, Back glass information: step 7, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Back glass information: step 7, image 2 of 2
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button.
      • There are multiple spring contacts around the perimeter of the phone.
      • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
      Ask FixBot
    4. iPhone 16 Pro Taptic Engine Removal, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Pro Taptic Engine Removal, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Pro Taptic Engine Removal, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. iPhone 16 Pro Taptic Engine Removal, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 16 Pro Taptic Engine Removal, Separate the bottom right corner adhesive: step 10, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Separate the bottom right corner adhesive: step 10, image 2 of 2
      • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
      • Don't insert the pick deeper than 3 mm near the volume buttons to avoid damaging the wireless charging/flash cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 16 Pro Taptic Engine Removal, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 16 Pro Taptic Engine Removal, Separate the left edge adhesive: step 12, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Separate the left edge adhesive: step 12, image 2 of 2
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone 16 Pro Taptic Engine Removal, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
      Ask FixBot
    10. iPhone 16 Pro Taptic Engine Removal, Separate the top edge adhesive: step 14, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Separate the top edge adhesive: step 14, image 2 of 2
      • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
      • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
      • You'll hear and feel clicks as the top two clips release.
      Ask FixBot
    11. iPhone 16 Pro Taptic Engine Removal, Swing open the back glass: step 15, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Swing open the back glass: step 15, image 2 of 2
      • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
      • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
      • Gently swing open the back glass towards the volume buttons.
      • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
      • Remove the opening picks.
      • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
      Ask FixBot
    12. iPhone 16 Pro Taptic Engine Removal, Remove the lower connector cover: step 16, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Remove the lower connector cover: step 16, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
      • Two 1.2 mm‑long screws
      • One 1.0 mm‑long screw
      • Small iFixit Phillips bits are designed to work with JIS screws, so you can use an iFixit PH 00 driver. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
      Ask FixBot
    13. iPhone 16 Pro Taptic Engine Removal: step 17, image 1 of 3 iPhone 16 Pro Taptic Engine Removal: step 17, image 2 of 3 iPhone 16 Pro Taptic Engine Removal: step 17, image 3 of 3
      • Use tweezers or your fingers to pick up and remove the lower connector cover.
      Ask FixBot
    14. iPhone 16 Pro Taptic Engine Removal, Disconnect the battery: step 18, image 1 of 3 iPhone 16 Pro Taptic Engine Removal, Disconnect the battery: step 18, image 2 of 3 iPhone 16 Pro Taptic Engine Removal, Disconnect the battery: step 18, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    15. iPhone 16 Pro Taptic Engine Removal, Remove the upper connector cover: step 19, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Remove the upper connector cover: step 19, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
      • Two 1.0 mm‑long screws
      • One 1.2 mm‑long screw
      • One 1.6 mm‑long screw
      Ask FixBot
    16. iPhone 16 Pro Taptic Engine Removal: step 20, image 1 of 2 iPhone 16 Pro Taptic Engine Removal: step 20, image 2 of 2
      • Use tweezers or your fingers to pick up and remove the upper connector cover.
      Ask FixBot
    17. iPhone 16 Pro Taptic Engine Removal, Disconnect the back glass: step 21, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Disconnect the back glass: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the back glass press connector.
      Ask FixBot
    18. iPhone 16 Pro Taptic Engine Removal, Remove the back glass: step 22, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Remove the back glass: step 22, image 2 of 2
      • Lift the back glass off the frame and remove it.
      Ask FixBot
    1. iPhone 16 Pro Taptic Engine Removal, Remove the Taptic Engine cover: step 23, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Remove the Taptic Engine cover: step 23, image 2 of 2
      • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
      • One 3.0 mm‑long screw
      • Two 1.7 mm‑long screws
      Ask FixBot
    2. iPhone 16 Pro Taptic Engine Removal: step 24, image 1 of 3 iPhone 16 Pro Taptic Engine Removal: step 24, image 2 of 3 iPhone 16 Pro Taptic Engine Removal: step 24, image 3 of 3
      • Use tweezers or your fingers to lift the top edge of the Taptic Engine cover.
      • Once the bottom edge unlatches from the frame, remove the Taptic Engine cover.
      Ask FixBot
    3. iPhone 16 Pro Taptic Engine Removal, Disconnect the lower assembly cable: step 25, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Disconnect the lower assembly cable: step 25, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the lower assembly cable press connector from the logic board.
      Ask FixBot
    4. iPhone 16 Pro Taptic Engine Removal: step 26, image 1 of 3 iPhone 16 Pro Taptic Engine Removal: step 26, image 2 of 3 iPhone 16 Pro Taptic Engine Removal: step 26, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two press connectors near the bottom right edge of the frame.
      Ask FixBot
    5. iPhone 16 Pro Taptic Engine Removal: step 27, image 1 of 2 iPhone 16 Pro Taptic Engine Removal: step 27, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the lower assembly cable.
      Ask FixBot
    6. iPhone 16 Pro Taptic Engine Removal: step 28, image 1 of 2 iPhone 16 Pro Taptic Engine Removal: step 28, image 2 of 2
      • Use an iOpener or hair dryer to heat up the lower assembly cable section on top of the Taptic Engine until it's hot to the touch.
      Ask FixBot
    7. iPhone 16 Pro Taptic Engine Removal: step 29, image 1 of 2 iPhone 16 Pro Taptic Engine Removal: step 29, image 2 of 2
      • Slide an opening pick under the lower assembly cable to separate it from the Taptic Engine.
      • Carefully bend the cable out of the way so you can access the Taptic Engine.
      Ask FixBot
    8. iPhone 16 Pro Taptic Engine Removal, Remove the Taptic Engine: step 30, image 1 of 2 iPhone 16 Pro Taptic Engine Removal, Remove the Taptic Engine: step 30, image 2 of 2
      • Use a Phillips screwdriver to remove the 1.9 mm‑long screw securing the Taptic Engine.
      Ask FixBot
    9. iPhone 16 Pro Taptic Engine Removal: step 31, image 1 of 2 iPhone 16 Pro Taptic Engine Removal: step 31, image 2 of 2
      • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
      Ask FixBot
    10. iPhone 16 Pro Taptic Engine Removal: step 32, image 1 of 3 iPhone 16 Pro Taptic Engine Removal: step 32, image 2 of 3 iPhone 16 Pro Taptic Engine Removal: step 32, image 3 of 3
      • Use the point of a spudger to pry up the Taptic Engine from its top-right corner.
      • Be careful not to pry against the battery.
      • Remove the Taptic Engine.
      Ask FixBot
To reassemble your iPhone, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
70,853 Reputation
363 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 32
All Time: 276
