Shop the Holiday Gift Guide
iPhone 16 Pro Screen Removal
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
42
All Time:
1,090
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to remove the screen on an iPhone 16 Pro.
Tools
    1. iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: step 1, image 2 of 2
      • Before you begin:
      • Back up your data.
      • Discharge the phone's battery drain below 25%. A charged lithium‑ion battery can catch fire if accidentally damaged.
      • Unplug any cables, and remove all cases, covers, and accessories (like portable chargers).
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Pro Screen Removal, Cracked glass preparation: step 2, image 1 of 2 iPhone 16 Pro Screen Removal, Cracked glass preparation: step 2, image 2 of 2
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape on the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 16 Pro Screen Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro Screen Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro Screen Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too deep, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      • On all edges, keep the opening pick at least 2 mm deep to avoid putting pressure on the glass itself.
      Ask FixBot
    4. iPhone 16 Pro Screen Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro Screen Removal, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
      Ask FixBot
    1. iPhone 16 Pro Screen Removal, Create a gap with a suction handle: step 5, image 1 of 1
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • The next two steps show how to create an initial gap using a suction handle.
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
      Ask FixBot
    2. iPhone 16 Pro Screen Removal: step 6, image 1 of 3 iPhone 16 Pro Screen Removal: step 6, image 2 of 3 iPhone 16 Pro Screen Removal: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • If you can't create a gap, apply more heat to the edge and try again.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 16 Pro Screen Removal, Screen information: step 7, image 1 of 1
      • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
      • Multiple spring contacts around the perimeter of the iPhone
      Ask FixBot
    4. iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: step 8, image 3 of 3
      • Slide the opening pick along the bottom edge to release the adhesive.
      • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
      • If the adhesive feels difficult to slice, reheat the edge for a minute.
      • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. iPhone 16 Pro Screen Removal, Heat the left edge: step 9, image 1 of 1
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
      Ask FixBot
    6. iPhone 16 Pro Screen Removal, Separate the left adhesive: step 10, image 1 of 2 iPhone 16 Pro Screen Removal, Separate the left adhesive: step 10, image 2 of 2
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
      • Insert a second opening pick in the bottom-left corner, close to the existing pick.
      • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 16 Pro Screen Removal, Separate the remaining adhesives: step 11, image 1 of 3 iPhone 16 Pro Screen Removal, Separate the remaining adhesives: step 11, image 2 of 3 iPhone 16 Pro Screen Removal, Separate the remaining adhesives: step 11, image 3 of 3
      • Repeat the heating and slicing procedure along the remaining screen edges.
      Ask FixBot
    8. iPhone 16 Pro Screen Removal, Swing open the screen: step 12, image 1 of 3 iPhone 16 Pro Screen Removal, Swing open the screen: step 12, image 2 of 3 iPhone 16 Pro Screen Removal, Swing open the screen: step 12, image 3 of 3
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
      • Carefully lift the screen upwards until the clips along the long edges clear the frame.
      • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
      Ask FixBot
    9. iPhone 16 Pro Screen Removal, Remove the connector covers: step 13, image 1 of 1
      • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
      Ask FixBot
    10. iPhone 16 Pro Screen Removal: step 14, image 1 of 3 iPhone 16 Pro Screen Removal: step 14, image 2 of 3 iPhone 16 Pro Screen Removal: step 14, image 3 of 3
      • Use tweezers to grasp the front sensor connector cover near the screw hole.
      • Lift and remove the cover.
      Ask FixBot
    11. iPhone 16 Pro Screen Removal: step 15, image 1 of 3 iPhone 16 Pro Screen Removal: step 15, image 2 of 3 iPhone 16 Pro Screen Removal: step 15, image 3 of 3
      • Repeat this process for the other cover.
      Ask FixBot
    12. iPhone 16 Pro Screen Removal, Disconnect the screen: step 16, image 1 of 2 iPhone 16 Pro Screen Removal, Disconnect the screen: step 16, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the display press connector.
      Ask FixBot
    13. iPhone 16 Pro Screen Removal: step 17, image 1 of 2 iPhone 16 Pro Screen Removal: step 17, image 2 of 2
      • Repeat this process for the front sensor press connector.
      Ask FixBot
    14. iPhone 16 Pro Screen Removal, Remove the screen: step 18, image 1 of 1
      • Remove the screen.
      Ask FixBot
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
70,853 Reputation
363 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 42
All Time: 1,090
