iPhone 16 Pro Max Battery Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16 Pro Max Battery Installation, Install the replacement battery: step 1, image 1 of 2 iPhone 16 Pro Max Battery Installation, Install the replacement battery: step 1, image 2 of 2
      • Remove any remaining adhesive from the battery recess. Wipe the frame surface with a lint-free cloth and a few drops of isopropyl alcohol.
      Ask FixBot
    2. iPhone 16 Pro Max Battery Installation: step 2, image 1 of 1
      Tool used on this step:
      Stretch Release Battery Adhesive
      $3.99
      Buy
      Ask FixBot
    3. iPhone 16 Pro Max Battery Installation: step 3, image 1 of 2 iPhone 16 Pro Max Battery Installation: step 3, image 2 of 2
      • The battery adhesive is very sticky! Be careful as you align the battery in its recess—once it sticks, you won't be able to realign it.
      • Lower the battery partially into its recess.
      • Temporarily connect the battery to the logic board to ensure that the cable reaches.
      • Lay the battery in its recess.
      Ask FixBot
    4. iPhone 16 Pro Max Battery Installation: step 4, image 1 of 2 iPhone 16 Pro Max Battery Installation: step 4, image 2 of 2
      • Use your fingers to press firmly against the battery for ten seconds to bond it to the frame.
      • Disconnect the battery from the logic board.
      Ask FixBot
Finish Line
Arthur Shi
350,781 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 187
