Introduction
Follow the steps in this guide to replace your iPad mini 4 display assembly, including the fused LCD and digitizer glass.
This procedure involves removing the screen then transferring the home button to your new assembly. In order to maintain Touch ID functionality you must transfer your original home button to the new screen.
Depending on your replacement part, you may also need to transfer the sleep/wake sensor for Smart Cover use, this portion of the procedure requires desoldering a cable.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the LTE model. The procedure is the same for both models except where noted.
Tool used on this step:Safety Glasses$3.19
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. For particularly bad breaks, you may need to lay down two layers.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Apply a suction cup halfway up the heated side.
Be sure the cup is completely flat on the screen to get a tight seal.
While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
Continue moving the opening pick down the side of the display to release the adhesive.
If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
Leave the opening picks in place and reheat the iOpener.
Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
Rotate the new pick around the lower right corner of the device.
Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
Lift the display from the top edge to open the device.
Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
Use the pointed tip of a spudger to flip up the retaining flap on the home button ZIF socket.
Use tweezers to unplug the home button ribbon cable from the ZIF socket.
Continue peeling the ribbon cable up to the EMI shield.
Use an opening pick to continue separating the home button ribbon cable from the display assembly.
Heat an iOpener and lay it over the lower edge of the front panel to soften the adhesive holding the home button in place.
Slowly push the home button up and out of the display assembly to separate the gasket from the front panel.
Examine your replacement part, and your original display carefully to be sure they match.
Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component.
Desolder the six solder pads from the lower left of the display to remove the sensor assembly cable.
