iPad Pro 9.7" Display Assembly Disconnect
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Pro 9.7" Display Assembly Disconnect, Remove the three screws securing the bracket: step 1, image 1 of 1
    • Remove the three 1.3 mm Phillips #000 screws securing the display cable bracket.
  2. iPad Pro 9.7" Display Assembly Disconnect, Remove the bracket: step 2, image 1 of 2 iPad Pro 9.7" Display Assembly Disconnect, Remove the bracket: step 2, image 2 of 2
    • Remove the display cable bracket.
  3. iPad Pro 9.7" Display Assembly Disconnect, Disconnect the display assembly: step 3, image 1 of 2 iPad Pro 9.7" Display Assembly Disconnect, Disconnect the display assembly: step 3, image 2 of 2
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  4. iPad Pro 9.7" Display Assembly Disconnect: step 4, image 1 of 2 iPad Pro 9.7" Display Assembly Disconnect: step 4, image 2 of 2
    • Repeat the previous step for the two remaining connectors.
  5. iPad Pro 9.7" Display Assembly Disconnect, Remove the display assembly: step 5, image 1 of 2 iPad Pro 9.7" Display Assembly Disconnect, Remove the display assembly: step 5, image 2 of 2
Arthur Shi
256,210 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,678 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 121
