iPad Display Assembly 3 Pc. Adhesive Application
  1. iPad Display Assembly 3 Pc. Adhesive Application, iPad Display Assembly 3 Pc. Adhesive Application: step 1, image 1 of 2 iPad Display Assembly 3 Pc. Adhesive Application, iPad Display Assembly 3 Pc. Adhesive Application: step 1, image 2 of 2
    • Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue.
    • Use tweezers to pull up sections of tape residue.
    • Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive.
    • Remove the residue by wiping in one direction to prevent smearing.
    • Do not scrape with a metal tool, or you will scratch the display assembly's surface.
  2. iPad Display Assembly 3 Pc. Adhesive Application: step 2, image 1 of 1
    • Lay out the replacement adhesive strips around the display assembly so that they correspond to the correct sides.
  3. iPad Display Assembly 3 Pc. Adhesive Application: step 3, image 1 of 2 iPad Display Assembly 3 Pc. Adhesive Application: step 3, image 2 of 2
    • Each adhesive strip is encased in four layers of plastic—three on top and one on the bottom.
    • Peel and remove the topmost plastic cling layer from the left adhesive strip.
    • Peel and remove the bottom plastic liner from the strip.
    • The top of the adhesive strip should still be covered by a colored plastic layer as well as a clear plastic stiffening layer.
    • The bottom of the adhesive strip should now be exposed and sticky.
  4. iPad Display Assembly 3 Pc. Adhesive Application: step 4, image 1 of 2 iPad Display Assembly 3 Pc. Adhesive Application: step 4, image 2 of 2
    • If there are extra bits of adhesive on the strip that are not required for your particular model of iPad, remove them now.
  5. iPad Display Assembly 3 Pc. Adhesive Application: step 5, image 1 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 5, image 2 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 5, image 3 of 3
    • Align the left adhesive strip to the left edge of the display assembly.
    • Beginning from one corner, lay the adhesive strip onto the display assembly and press the strip into place.
  6. iPad Display Assembly 3 Pc. Adhesive Application: step 6, image 1 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 6, image 2 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 6, image 3 of 3
    • Repeat the process with the right adhesive strip.
    • Peel and remove the topmost cling layer from the strip.
    • Peel and remove the bottom liner layer from the strip.
    • Align the adhesive strip to the right edge of the display assembly.
    • Starting from one corner, lay the adhesive strip onto the display assembly and press in place.
  7. iPad Display Assembly 3 Pc. Adhesive Application: step 7, image 1 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 7, image 2 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 7, image 3 of 3
    • Repeat the process for the top adhesive strip.
    • Peel and remove the bottom liner from the strip.
    • Align the strip to the top of the display assembly such that the straight adhesive line bridges the gap between the left and right strips.
    • Press the strip in place.
  8. iPad Display Assembly 3 Pc. Adhesive Application: step 8, image 1 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 8, image 2 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 8, image 3 of 3
    • Peel and remove the clear plastic stiffening layer from all three adhesive strip sections.
    • The adhesive strips should still be covered by colored plastic liners.
  9. iPad Display Assembly 3 Pc. Adhesive Application: step 9, image 1 of 1
    • Continue with the reassembly process until you are ready to seal the device.
  10. iPad Display Assembly 3 Pc. Adhesive Application: step 10, image 1 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 10, image 2 of 3 iPad Display Assembly 3 Pc. Adhesive Application: step 10, image 3 of 3
    • Peel and remove the three colored plastic liners to expose the adhesive.
    • Close the device and stack some heavy books on top of it for thirty minutes to help the new adhesive bond.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Arthur Shi
253,292 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,147 Guides authored
Past 24 Hours: 24
Past 7 Days: 150
Past 30 Days: 705
All Time: 39,279
