Huawei P30 Pro Daughterboard Cover Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
25
All Time:
265
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
daughterboard cover prereq only
Parts
  • Tesa 61395 Double-Sided Tape
    4.9
Tools
    1. Huawei P30 Pro Daughterboard Cover Replacement, Rear Glass: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Huawei P30 Pro Daughterboard Cover Replacement: step 2, image 1 of 3 Huawei P30 Pro Daughterboard Cover Replacement: step 2, image 2 of 3 Huawei P30 Pro Daughterboard Cover Replacement: step 2, image 3 of 3
      • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner.
      Ask FixBot
    3. Huawei P30 Pro Daughterboard Cover Replacement: step 3, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Huawei P30 Pro Daughterboard Cover Replacement: step 4, image 1 of 3 Huawei P30 Pro Daughterboard Cover Replacement: step 4, image 2 of 3 Huawei P30 Pro Daughterboard Cover Replacement: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
      • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Huawei P30 Pro Daughterboard Cover Replacement: step 5, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 5, image 2 of 2
      • If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the back cover.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Huawei P30 Pro Daughterboard Cover Replacement: step 6, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    7. Huawei P30 Pro Daughterboard Cover Replacement: step 7, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 7, image 2 of 2
      • Lift and remove the back cover.
      • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
      Ask FixBot
    1. Huawei P30 Pro Daughterboard Cover Replacement, Motherboard Cover with NFC & Charging Coil: step 8, image 1 of 1
      • Remove the ten Phillips #00 screws (4.3 mm length).
      Ask FixBot
    2. Huawei P30 Pro Daughterboard Cover Replacement: step 9, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 9, image 2 of 2
      • Slide an opening pick under the black adhesive at the bottom right of the charging coil.
      • Carefully loosen the adhesive with the opening pick.
      Ask FixBot
    3. Huawei P30 Pro Daughterboard Cover Replacement: step 10, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 10, image 2 of 2
      • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
      Ask FixBot
    4. Huawei P30 Pro Daughterboard Cover Replacement: step 11, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 11, image 2 of 2
      • Slide an opening pick under the left side of the motherboard cover.
      • Unhinge the left side of the motherboard cover by slightly rotating the opening pick.
      Ask FixBot
    5. Huawei P30 Pro Daughterboard Cover Replacement: step 12, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 12, image 2 of 2
      • Push the motherboard cover out of the sockets at the top edge of the phone beginning with the top left corner.
      • Remove the motherboard cover including the NFC and charging coil.
      Ask FixBot
    1. Huawei P30 Pro Daughterboard Cover Replacement, Battery Disconnect: step 13, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement, Battery Disconnect: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the battery connector.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      Ask FixBot
    1. Huawei P30 Pro Daughterboard Cover Replacement, Daughterboard Cover: step 14, image 1 of 1
      • Remove the five Phillips #00 screws (4.3 mm length).
      • Some of these screws may be hidden under adhesive. Carefully peel the adhesive to uncover these screws.
      Ask FixBot
    2. Huawei P30 Pro Daughterboard Cover Replacement: step 15, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 15, image 2 of 2
      • Slide an opening pick under the top edge of the daughterboard cover.
      • Pry up and unhinge the daughterboard cover by slightly rotating the opening pick.
      Ask FixBot
    3. Huawei P30 Pro Daughterboard Cover Replacement: step 16, image 1 of 2 Huawei P30 Pro Daughterboard Cover Replacement: step 16, image 2 of 2
      • Remove the daughterboard cover.
      Ask FixBot
Dominik Schnabelrauch
266,842 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 25
All Time: 265
