Introduction
This is a prerequisite only guide for the front panel replacement.
Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
Carefully pull the home button ribbon cable straight out of the ZIF connector.
Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
Tool used on this step:Polyimide Tape$9.99
Remove the front panel assembly.
These areas, which are part of the digitizer, are covered by foam adhesive on your iPad's original front panel. Some replacement panels leave this area exposed, which can cause it to ground out against other components. You can protect it by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape.
