iPad 6 Wi-Fi Front Panel Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 2 iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 2
    • Remove any tape covering the home button ribbon cable connector.
  2. iPad 6 Wi-Fi Front Panel Assembly Replacement: step 2, image 1 of 3 iPad 6 Wi-Fi Front Panel Assembly Replacement: step 2, image 2 of 3 iPad 6 Wi-Fi Front Panel Assembly Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  3. iPad 6 Wi-Fi Front Panel Assembly Replacement: step 3, image 1 of 3 iPad 6 Wi-Fi Front Panel Assembly Replacement: step 3, image 2 of 3 iPad 6 Wi-Fi Front Panel Assembly Replacement: step 3, image 3 of 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  4. iPad 6 Wi-Fi Front Panel Assembly Replacement: step 4, image 1 of 2 iPad 6 Wi-Fi Front Panel Assembly Replacement: step 4, image 2 of 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  5. iPad 6 Wi-Fi Front Panel Assembly Replacement: step 5, image 1 of 2 iPad 6 Wi-Fi Front Panel Assembly Replacement: step 5, image 2 of 2
    Tool used on this step:
    Polyimide Tape
    $9.99
    Buy
    • Remove the front panel assembly.
    • During reassembly, to prevent "ghost" or "phantom" touch input issues with your iPad, check to make sure there is a layer of foam or tape covering the metal frame on the back of the glass.
    • These areas, which are part of the digitizer, are covered by foam adhesive on your iPad's original front panel. Some replacement panels leave this area exposed, which can cause it to ground out against other components. You can protect it by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape.
Sam Goldheart
466,252 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,449 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 150
