iPad 5 Wi-Fi Logic Board Replacement
  1. iPad 5 Wi-Fi Logic Board Replacement, iOpener Heating: step 1, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement, iOpener Heating: step 1, image 2 of 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 5 Wi-Fi Logic Board Replacement: step 2, image 1 of 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100ËšC (212ËšF).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 5 Wi-Fi Logic Board Replacement: step 3, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 5 Wi-Fi Logic Board Replacement, Alternate iOpener heating method: step 4, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement, Alternate iOpener heating method: step 4, image 2 of 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 5 Wi-Fi Logic Board Replacement, Front Panel: step 5, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement, Front Panel: step 5, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement, Front Panel: step 5, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad 5 Wi-Fi Logic Board Replacement: step 6, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 6, image 2 of 2
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
  7. iPad 5 Wi-Fi Logic Board Replacement: step 7, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 7, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 7, image 3 of 3
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
  8. iPad 5 Wi-Fi Logic Board Replacement, Anti-Clamp instructions: step 8, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement, Anti-Clamp instructions: step 8, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement, Anti-Clamp instructions: step 8, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  9. iPad 5 Wi-Fi Logic Board Replacement: step 9, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 9, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 9, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  10. iPad 5 Wi-Fi Logic Board Replacement: step 10, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 10, image 2 of 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  11. iPad 5 Wi-Fi Logic Board Replacement: step 11, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 11, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 11, image 3 of 3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
  12. iPad 5 Wi-Fi Logic Board Replacement: step 12, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 12, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 12, image 3 of 3
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  13. iPad 5 Wi-Fi Logic Board Replacement: step 13, image 1 of 1
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  14. iPad 5 Wi-Fi Logic Board Replacement: step 14, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 14, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 14, image 3 of 3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
  15. iPad 5 Wi-Fi Logic Board Replacement: step 15, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 15, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 15, image 3 of 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  16. iPad 5 Wi-Fi Logic Board Replacement: step 16, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 16, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 16, image 3 of 3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  17. iPad 5 Wi-Fi Logic Board Replacement: step 17, image 1 of 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  18. iPad 5 Wi-Fi Logic Board Replacement: step 18, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 18, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 18, image 3 of 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  19. iPad 5 Wi-Fi Logic Board Replacement: step 19, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 19, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 19, image 3 of 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
  20. iPad 5 Wi-Fi Logic Board Replacement: step 20, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 20, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 20, image 3 of 3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  21. iPad 5 Wi-Fi Logic Board Replacement: step 21, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 21, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 21, image 3 of 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
  22. iPad 5 Wi-Fi Logic Board Replacement: step 22, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 22, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 22, image 3 of 3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  23. iPad 5 Wi-Fi Logic Board Replacement: step 23, image 1 of 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPad—along the volume and lock buttons.
  24. iPad 5 Wi-Fi Logic Board Replacement: step 24, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 24, image 2 of 2
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  25. iPad 5 Wi-Fi Logic Board Replacement: step 25, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 25, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 25, image 3 of 3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  26. iPad 5 Wi-Fi Logic Board Replacement: step 26, image 1 of 1
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
  27. iPad 5 Wi-Fi Logic Board Replacement: step 27, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 27, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 27, image 3 of 3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  28. iPad 5 Wi-Fi Logic Board Replacement: step 28, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 28, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 28, image 3 of 3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  29. iPad 5 Wi-Fi Logic Board Replacement: step 29, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 29, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 29, image 3 of 3
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
  30. iPad 5 Wi-Fi Logic Board Replacement: step 30, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 30, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 30, image 3 of 3
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
  31. iPad 5 Wi-Fi Logic Board Replacement: step 31, image 1 of 1
    • Reheat and reapply the iOpener to the volume control side of the iPad.
  32. iPad 5 Wi-Fi Logic Board Replacement: step 32, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 32, image 2 of 2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
  33. iPad 5 Wi-Fi Logic Board Replacement: step 33, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 33, image 2 of 2
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
  34. iPad 5 Wi-Fi Logic Board Replacement: step 34, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 34, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 34, image 3 of 3
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
  35. iPad 5 Wi-Fi Logic Board Replacement: step 35, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 35, image 2 of 2
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
  36. iPad 5 Wi-Fi Logic Board Replacement, LCD: step 36, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement, LCD: step 36, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement, LCD: step 36, image 3 of 3
    • Remove any tape obscuring the LCD screws.
  37. iPad 5 Wi-Fi Logic Board Replacement: step 37, image 1 of 1
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
  38. iPad 5 Wi-Fi Logic Board Replacement: step 38, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 38, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 38, image 3 of 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  39. iPad 5 Wi-Fi Logic Board Replacement: step 39, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 39, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 39, image 3 of 3
    Battery Blocker
    $3.99
    Buy
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
  40. iPad 5 Wi-Fi Logic Board Replacement: step 40, image 1 of 1
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
  41. iPad 5 Wi-Fi Logic Board Replacement: step 41, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 41, image 2 of 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  42. iPad 5 Wi-Fi Logic Board Replacement: step 42, image 1 of 1
    • Remove the LCD.
  43. iPad 5 Wi-Fi Logic Board Replacement, Front Panel Assembly: step 43, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement, Front Panel Assembly: step 43, image 2 of 2
    • Remove any tape covering the home button ribbon cable connector.
  44. iPad 5 Wi-Fi Logic Board Replacement: step 44, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 44, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 44, image 3 of 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
  45. iPad 5 Wi-Fi Logic Board Replacement: step 45, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 45, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 45, image 3 of 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  46. iPad 5 Wi-Fi Logic Board Replacement: step 46, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 46, image 2 of 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  47. iPad 5 Wi-Fi Logic Board Replacement: step 47, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 47, image 2 of 2
    Polyimide Tape
    $9.99
    Buy
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  48. iPad 5 Wi-Fi Logic Board Replacement, Right Antenna: step 48, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement, Right Antenna: step 48, image 2 of 2
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
  49. iPad 5 Wi-Fi Logic Board Replacement: step 49, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 49, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 49, image 3 of 3
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
  50. iPad 5 Wi-Fi Logic Board Replacement: step 50, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 50, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 50, image 3 of 3
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
  51. iPad 5 Wi-Fi Logic Board Replacement: step 51, image 1 of 1
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
  52. iPad 5 Wi-Fi Logic Board Replacement: step 52, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 52, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 52, image 3 of 3
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
  53. iPad 5 Wi-Fi Logic Board Replacement: step 53, image 1 of 1
    • Remove the right antenna from the iPad.
  54. iPad 5 Wi-Fi Logic Board Replacement, Right Speaker: step 54, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement, Right Speaker: step 54, image 2 of 2
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
  55. iPad 5 Wi-Fi Logic Board Replacement: step 55, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 55, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 55, image 3 of 3
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
  56. iPad 5 Wi-Fi Logic Board Replacement: step 56, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 56, image 2 of 2
    Buy
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
  57. iPad 5 Wi-Fi Logic Board Replacement: step 57, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 57, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 57, image 3 of 3
    • Peel the tape toward the home button to uncover the speaker cable connector.
  58. iPad 5 Wi-Fi Logic Board Replacement: step 58, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 58, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 58, image 3 of 3
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
  59. iPad 5 Wi-Fi Logic Board Replacement: step 59, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 59, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 59, image 3 of 3
    • Remove the tape holding the speaker to the rear case.
  60. iPad 5 Wi-Fi Logic Board Replacement: step 60, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 60, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 60, image 3 of 3
    • Carefully peel the LCD buffer tape up off of the rear case.
  61. iPad 5 Wi-Fi Logic Board Replacement: step 61, image 1 of 1
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  62. iPad 5 Wi-Fi Logic Board Replacement: step 62, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 62, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 62, image 3 of 3
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
  63. iPad 5 Wi-Fi Logic Board Replacement: step 63, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 63, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 63, image 3 of 3
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
  64. iPad 5 Wi-Fi Logic Board Replacement, Upper Component Cable Bracket: step 64, image 1 of 1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  65. iPad 5 Wi-Fi Logic Board Replacement: step 65, image 1 of 1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  66. iPad 5 Wi-Fi Logic Board Replacement, Logic Board: step 66, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement, Logic Board: step 66, image 2 of 2
    • There are two remaining pieces of tape securing the left antenna cable to the rear case.
  67. iPad 5 Wi-Fi Logic Board Replacement: step 67, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 67, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 67, image 3 of 3
    • Push the bracket away from the speaker until it is clear of the tape underneath.
  68. iPad 5 Wi-Fi Logic Board Replacement: step 68, image 1 of 1
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
  69. iPad 5 Wi-Fi Logic Board Replacement: step 69, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 69, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 69, image 3 of 3
  70. iPad 5 Wi-Fi Logic Board Replacement: step 70, image 1 of 1
    • Remove the left antenna from the iPad.
  71. iPad 5 Wi-Fi Logic Board Replacement: step 71, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 71, image 2 of 2
    • Remove the tape covering the left speaker cable connector.
  72. iPad 5 Wi-Fi Logic Board Replacement: step 72, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 72, image 2 of 2
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  73. iPad 5 Wi-Fi Logic Board Replacement: step 73, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 73, image 2 of 2
  74. iPad 5 Wi-Fi Logic Board Replacement: step 74, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 74, image 2 of 2
  75. iPad 5 Wi-Fi Logic Board Replacement: step 75, image 1 of 1
  76. iPad 5 Wi-Fi Logic Board Replacement: step 76, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 76, image 2 of 2
    • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
  77. iPad 5 Wi-Fi Logic Board Replacement: step 77, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 77, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 77, image 3 of 3
  78. iPad 5 Wi-Fi Logic Board Replacement: step 78, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 78, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 78, image 3 of 3
    • Remove the left speaker from the iPad.
  79. iPad 5 Wi-Fi Logic Board Replacement: step 79, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 79, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 79, image 3 of 3
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Pry up only on the connector—not on the socket itself.
    • Fold the front-facing camera cable out of the way.
    • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
  80. iPad 5 Wi-Fi Logic Board Replacement: step 80, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 80, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 80, image 3 of 3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Fold the rear-facing camera cable out of the way.
  81. iPad 5 Wi-Fi Logic Board Replacement: step 81, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 81, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 81, image 3 of 3
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
    • Fold the headphone jack cable out of the way.
  82. iPad 5 Wi-Fi Logic Board Replacement: step 82, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 82, image 2 of 2
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  83. iPad 5 Wi-Fi Logic Board Replacement: step 83, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 83, image 2 of 2
    • Remove any tape covering the upper button assembly cable connector.
  84. iPad 5 Wi-Fi Logic Board Replacement: step 84, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 84, image 2 of 2
    • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
  85. iPad 5 Wi-Fi Logic Board Replacement: step 85, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 85, image 2 of 2
    • Slide the upper button assembly cable straight out of its ZIF connector.
  86. iPad 5 Wi-Fi Logic Board Replacement: step 86, image 1 of 1
    • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
    • To find these screws, hold the iPad vertically and look down at the Lightning port.
  87. iPad 5 Wi-Fi Logic Board Replacement: step 87, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 87, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 87, image 3 of 3
    • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
    • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
    • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
  88. iPad 5 Wi-Fi Logic Board Replacement: step 88, image 1 of 1
    • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
    • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
  89. iPad 5 Wi-Fi Logic Board Replacement: step 89, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 89, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 89, image 3 of 3
    • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
    • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
    • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
  90. iPad 5 Wi-Fi Logic Board Replacement: step 90, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 90, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 90, image 3 of 3
    • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
  91. iPad 5 Wi-Fi Logic Board Replacement: step 91, image 1 of 1
    • Place a heated iOpener along the bottom edge of the iPad.
    • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  92. iPad 5 Wi-Fi Logic Board Replacement: step 92, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 92, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 92, image 3 of 3
    • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
    • Insert an opening pick under the Lightning cable where it meets the logic board.
    • Slide the pick down and around the bend in the cable.
  93. iPad 5 Wi-Fi Logic Board Replacement: step 93, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 93, image 2 of 2
    • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
    • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  94. iPad 5 Wi-Fi Logic Board Replacement: step 94, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 94, image 2 of 2
    • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
  95. iPad 5 Wi-Fi Logic Board Replacement: step 95, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 95, image 2 of 2
    • Pull the Lightning connector straight out of its recess in the rear case.
  96. iPad 5 Wi-Fi Logic Board Replacement: step 96, image 1 of 1
    • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
    • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  97. iPad 5 Wi-Fi Logic Board Replacement: step 97, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 97, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 97, image 3 of 3
    • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
    • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
  98. iPad 5 Wi-Fi Logic Board Replacement: step 98, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 98, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 98, image 3 of 3
    • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
    • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
  99. iPad 5 Wi-Fi Logic Board Replacement: step 99, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 99, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 99, image 3 of 3
    • Slide an opening pick under the logic board between it and the battery.
    • Slide the pick from the base to the center of the logic board to cut the adhesive.
    • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  100. iPad 5 Wi-Fi Logic Board Replacement: step 100, image 1 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 100, image 2 of 3 iPad 5 Wi-Fi Logic Board Replacement: step 100, image 3 of 3
    • Slide the pick up the length of the logic board.
    • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
  101. iPad 5 Wi-Fi Logic Board Replacement: step 101, image 1 of 2 iPad 5 Wi-Fi Logic Board Replacement: step 101, image 2 of 2
    • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
    • Cut any adhesive holding the outer edge of the logic board to the rear case.
  102. iPad 5 Wi-Fi Logic Board Replacement: step 102, image 1 of 1
    • Remove the logic board from the iPad.
Evan Noronha
223,698 Reputation
168 Guides authored
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 149
All Time: 12,389
