Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
18
All Time:
313
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 35 - 45 minutes
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only! Use this guide to remove the motherboard cover including the charging coil on your Xiaomi Mi 10.
Tools
    1. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Heat the rear glass: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Insert the iFlex: step 2, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Insert the iFlex: step 2, image 2 of 2
      • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
      • The rear glass of the Xiaomi Mi 10 sits tightly in place. In order to create a gap that is big enough to insert an opening pick, you need to insert an iFlex first.
      • Insert the iFlex into the gap and leave it in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Begin to slice the adhesive: step 3, image 1 of 3 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Begin to slice the adhesive: step 3, image 2 of 3 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Begin to slice the adhesive: step 3, image 3 of 3
      • Insert an opening pick into the gap you created with the iFlex.
      • Slide the opening pick to the bottom right corner.
      • At this point you can remove the iFlex from the phone.
      Ask FixBot
    4. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the bottom edge adhesive: step 4, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the bottom edge adhesive: step 4, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the lefthand-side adhesive: step 5, image 1 of 3 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the lefthand-side adhesive: step 5, image 2 of 3 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the lefthand-side adhesive: step 5, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the top edge adhesive: step 6, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the top edge adhesive: step 6, image 2 of 2
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the righthand-side adhesive: step 7, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Slice the righthand-side adhesive: step 7, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    8. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Remove the rear glass: step 8, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Remove the rear glass: step 8, image 2 of 2
      • Remove the rear glass.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      Ask FixBot
    1. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Unfasten the screws: step 9, image 1 of 1
      • Remove the four 4.9 mm Phillips #00 screws.
      Ask FixBot
    2. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the charging coil adhesive: step 10, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the charging coil adhesive: step 10, image 2 of 2
      • Use an opening pick to slice the adhesive underneath the black protective mat covering the upper loudspeaker assembly.
      Ask FixBot
    3. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the bottom adhesive: step 11, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the bottom adhesive: step 11, image 2 of 2
      • Use an opening pick to slice the adhesive underneath the black protective mat covering the bottom loudspeaker assembly.
      Ask FixBot
    4. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the NFC & charging coil assembly: step 12, image 1 of 3 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the NFC & charging coil assembly: step 12, image 2 of 3 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Loosen the NFC & charging coil assembly: step 12, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • There is a small piece of protective copper foil underneath the NFC and charging coil assembly. Avoid damaging it during the following procedure.
      • Slide a plastic card or playing card underneath the NFC and charging coil assembly.
      • Use the card to carefully loosen the adhesive underneath the left edge of the assembly.
      • To make this process easier, you can apply a heated iOpener to the left edge of the NFC and charging coil assembly to soften the adhesive.
      • Do not remove the NFC and charging coil assembly all the way yet. It is still glued to the motherboard cover.
      Ask FixBot
    5. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Fold over the NFC & charging coil assembly: step 13, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Fold over the NFC & charging coil assembly: step 13, image 2 of 2
      • Carefully fold the NFC & charging coil assembly to the left side of the phone.
      Ask FixBot
    6. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Unfasten the screws: step 14, image 1 of 1
      • Remove the five 4.9 mm Phillips #00 screws.
      Ask FixBot
    7. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Pry up the motherboard cover: step 15, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Pry up the motherboard cover: step 15, image 2 of 2
      • Slide an opening pick underneath the bottom right edge of the motherboard cover.
      • Use the opening pick to pry up the motherboard cover.
      Ask FixBot
    8. Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Remove the motherboard cover: step 16, image 1 of 2 Xiaomi Mi 10 Motherboard Cover & Charging Coil Removal, Remove the motherboard cover: step 16, image 2 of 2
      • Remove the motherboard cover including the NFC and charging coil assembly.
      Ask FixBot
Dominik Schnabelrauch
266,702 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 313
