Xiaomi Redmi Note 10 Pro Midframe Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Xiaomi Redmi Note 10 Pro Midframe Replacement, Eject the SIM card tray: step 1, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Eject the SIM card tray: step 1, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Eject the SIM card tray: step 1, image 3 of 3
      • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Xiaomi Redmi Note 10 Pro Midframe Replacement, Heat the rear glass: step 2, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Redmi Note 10 Pro Midframe Replacement, Secure a suction handle: step 3, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Secure a suction handle: step 3, image 2 of 2
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • The surface of the rear glass is not completely smooth. For a better grip of the suction handle, apply tape to the rear glass or moisten the suction handle.
      • Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
      Ask FixBot
    3. Xiaomi Redmi Note 10 Pro Midframe Replacement, Create a gap: step 4, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Create a gap: step 4, image 2 of 2
      • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      Ask FixBot
    4. Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 5, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 5, image 2 of 2
      • Slide the opening pick to the top right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 6, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 6, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 6, image 3 of 3
      • Insert a second opening pick next to the top right corner.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 7, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 7, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Slice the adhesive: step 7, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Xiaomi Redmi Note 10 Pro Midframe Replacement: step 8, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement: step 8, image 2 of 2
      • Insert a fourth opening pick underneath the bottom left corner of your phone.
      • Slide the opening pick up to the volume button.
      • Don't slide the opening pick any further! A flex cable runs next to the volume button.
      Ask FixBot
    8. Xiaomi Redmi Note 10 Pro Midframe Replacement: step 9, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement: step 9, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement: step 9, image 3 of 3
      • Insert a sixth opening pick at the left edge of your phone next to the top end of the power and volume button cut out.
      • Slice the remaining adhesive of the left edge.
      • Slide the opening pick around the top left corner and along the top edge to cut the remaining adhesive.
      Ask FixBot
    9. Xiaomi Redmi Note 10 Pro Midframe Replacement, Remove the rear glass: step 10, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Remove the rear glass: step 10, image 2 of 2
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Xiaomi Redmi Note 10 Pro Midframe Replacement, Unscrew the midframe: step 11, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Unscrew the midframe: step 11, image 2 of 2
      • Use a Phillips screwdriver to remove the seventeen screws securing the midframe:
      • Nine 4.4 mm-long screws in the upper area of the midframe
      • Eight 3.4 mm-long screws in the lower area of the midframe
      Ask FixBot
    2. Xiaomi Redmi Note 10 Pro Midframe Replacement, Insert an opening pick: step 12, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Insert an opening pick: step 12, image 2 of 2
      • The midframe is held in place by plastic clips.
      • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charging port.
      • Slide the opening pick to the bottom left corner to release the plastic clips.
      Ask FixBot
    3. Xiaomi Redmi Note 10 Pro Midframe Replacement, Release the plastic clips: step 13, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Release the plastic clips: step 13, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Release the plastic clips: step 13, image 3 of 3
      • Slide the opening pick along the left edge of your phone to release the plastic clips.
      Ask FixBot
    4. Xiaomi Redmi Note 10 Pro Midframe Replacement: step 14, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement: step 14, image 2 of 2
      • Slide the opening pick along the top edge to release the plastic clips.
      Ask FixBot
    5. Xiaomi Redmi Note 10 Pro Midframe Replacement: step 15, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement: step 15, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement: step 15, image 3 of 3
      • Slide the opening pick along the right edge to release the remaining plastic clips.
      • Don't try to remove the midframe all the way yet! The side buttons are still connected to the motherboard by a flex cable.
      Ask FixBot
    6. Xiaomi Redmi Note 10 Pro Midframe Replacement, Swing open the midframe: step 16, image 1 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Swing open the midframe: step 16, image 2 of 3 Xiaomi Redmi Note 10 Pro Midframe Replacement, Swing open the midframe: step 16, image 3 of 3
      • Avoid straining the side button flex cable in the following step!
      • Carefully swing the midframe open in the direction of the power and volume buttons and place the midframe close to the phone assembly.
      Ask FixBot
    7. Xiaomi Redmi Note 10 Pro Midframe Replacement, Disconnect the power and volume button flex cable: step 17, image 1 of 2 Xiaomi Redmi Note 10 Pro Midframe Replacement, Disconnect the power and volume button flex cable: step 17, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the power and volume button flex cable from the motherboard.
      Ask FixBot
    8. Xiaomi Redmi Note 10 Pro Midframe Replacement, Remove the midframe: step 18, image 1 of 1
      • Remove the midframe.
      Ask FixBot
Adriana Zwink
69,118 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 21
All Time: 281
